Good Morning, I've discussed this topic before, but haven't found any more info or reasoning. My SDS100 is working fine, no issues. However, the same Squelch sensitivity is happening again. I have to lower squelch to 1 to monitor as normal, if I raise the squelch, transmissions do not pick up and constantly flicker on the display. I may be having some type of overbearing frequency or interference again somewhere.
Also, I purchased a Remtronix antenna and it appears to be bent or slanted when tightened on the device. As I turned left to tighten it it like shifts as it goes down. Is this common? Is there another antenna that's better for 800Mhz Digital P25 Systems?
Thank you for your time.
