State vs. Municipal Radio ID Allocation For Portables and Mobiles on CLRMN
adamfancher
Winsted, CT
So in the several years I've been helping maintain the Radio ID database I've grown used to recognizing ID's ending in 4xxx-6xxx as portables for state agencies and 1xxx-3xxx for municipalities.
It would seem as though Groton has broken tradition on this and as a result I am tearing my hair out, and I'm wondering if I have this to look forward to for other agencies...
nhfdcadet
GCT-1
New Hartford, Ct
My portable has a 6
adamfancher
Winsted, CT
Not your doing of course...Something for me to be aware of going forward, as Groton doesn't seem to be the only municipality that deviated from the typical format
adamfancher
Winsted, CT
Good for you man! That's awesome. I actually saved mine when I cut it a few years ago, never got around to donating it...
So I guess I'll add some exceptions to the intro on the list, already had to put a few in there for things like 4xxxx should be Avon but is really CT Transit, etc.
cg
Connecticut
CTTransit may be renumbered before Avon is up and running. I believe 189xxxx is the range they all will ultimately use.
nhfdcadet
GCT-1
New Hartford, Ct
thats A LOT of buses to go reprogram though, very time consuming.
also historically, ID's have not been reused, so even if they did move ct transit out of the 40000 range, those ID's die anyway.
SVFD440
CT
The format is MMMSUUU
MMM = Municipality
S = Type of Unit
UUU = Unit Number
0016123 would be a portable in Andover.
Groton is 059SUUU
adamfancher
Winsted, CT
MMM = Municipality
S = Type of Unit
UUU = Unit Number
Groton is 059SUUU
That part of the radio ID is well understood, and already posted in the information at the top of the listing.
The part in question is "S", or radio type.
In most cases, state agencies use 1-3 for mobiles and 4-6 for portables, while generally municipalities do the reverse.
However, it has been discovered that some municipalities follow the state standard, meaning, for instance, 594xxx is not a portable as one might expect, but rather a mobile radio as Groton chose to adhere to the state format.
Information section on the listing has been updated appropriately.
SVFD440
CT
There was a document that was posted on the state website that had it backwards. It has been since removed.
cg
Connecticut
I suppose Tax Town Avon (004) will not have so many radios that they cannot work around the CTTransit IDs, less than 200 subscribers if I recall. Still, nice if they would get them squared away. Probably only take someone a year or so :)
adamfancher
Winsted, CT
I wonder if in some cases certain agencies go to the 3-digit prefixes because they "run out" of ID's in the allocated range. For example, New Britain police seem to have now expanded to 198xxxx, Enfield seems to be using 735xxxx, etc.
nhfdcadet
GCT-1
New Hartford, Ct
if I had to guess, 198 is probably a state agency. Maybe CCSU PD or similar.
