Static Interference...help?
stepps7
New Jersey
I was wondering if for some odd reason, my computer (when left on), will cause my scanner to sound very staticky when transmitting? I have both items opposite from each other in my room, approx. 20 ft. apart. I have the Pro-2096 and when I hear certain transmissions, there seems to be alot of static interference. At first I thought it was my cordless phone, but I unplugged it and moved it out of the room. Could the computer be causing this problem if it is left on?
N
N_Jay
Guest
YES
(Ignore this line it is just added so the system will allow posting, seems the whole answer "Yes" is too short)
stepps7
New Jersey
So if I turn my computer off at night when I'm listening to my scanner, I shouldn't encounter static interference to the point where I can't even hear what there saying?
dougjgray
Englewood CO
Well my computer causes interference on my scanner with vhf not much from uhf/800 mhz. It seems to come mostly from the monitor and maybe usb devices try just shotting the monitor off
Al42
Long Island, NY, USA
No, your computer can be the cause of that interference. There could also be other causes, some under your control, some not.
If your computer is the cause of the interference, turning the computer off will eliminate the interference. (The only way you'll know is by turning the computer off and listening.)
bwhite
Carroll County, MD
I've seen monitors do it, also, check your power strip, some of them produce RF.
Best way to test is to unplug it all from the wall, and start adding things back until you get static.
Next turn on the power strip, quiet?
Now the monitor, quiet?
Now the PC and so forth.
