Static on Particular frequency
Gumball928
I have an SDS200 with DMR, NXDN and Pro-Voice installed, and I live in NW Oregon.
I have the frequency for Oregon Medivac (155.400) and all I receive is static when the scanner catches that frequency.
Is that because their transmissions are encrypted, or is something else ??
jasonhouk
Uniden AlphaMan
Uniden Representative
Marion, Ohio
A quick query for the state shows the following results:
Freq Out Freq InToneCallsignDescriptionCategoryAgency/CountyState
155.400AirLink Critical Care Pine MountainAirlink Critical Care
Transport - Bend
Medevac
Oregon MedevacOR
155.400KNDL424Airlink Pine Mountain remoteOther Fire/EMS
Deschutes County
DeschutesOR
155.400Samaritan Pacific Communities HospitalLincoln County
Lincoln County
LincolnOR
Also could be a birdie internally in the scanner.
  • Like
Reactions: wtp
dmfalk
Eureka
All the above data show analogue, no digital or encryption. It would be nice to know which county, though. You might be too far away, and receiving something else?
Gumball928
Columbia County
Gumball928
Freq OutFreq InToneCallsignDescriptionCategoryAgency/CountyState
Transport - Bend
Medevac
Oregon MedevacOR
Deschutes County
DeschutesOR
Lincoln County
LincolnOR
if it is a "birdie", how do I get rid of it ??
wtp
Port Charlotte FL
just to check.
this is one quick way to bee if it is a birdie
take the antenna off, yes all the way.
if you still hear it, it is either a birdie or something transmitting VERY close to you.
and if you can set the squelch all the way up and still hear it, it is a birdie.
they are internal to the radio and can't be stopped.
i do not know if the IFX thing changes that.
Gumball928
just to check.
Thank you for your assistance, but I tried those steps, and the "static" did not appear. Again, it is ONLY the Oregon Medivac where I get this.
Gumball928
reading other posts, it is more like a "buzzsaw" noise . . . .
jasonhouk
Uniden AlphaMan
Marion, Ohio
Definitely sounds like a very weak DMR signal. Can you post a short video or picture of the detailed display (include RSSI on the display) when you are hearing the anomaly?
