static
stuart3009
bit annoyed ive just recordered over 2 hrs of refulling and other transmissions and when i listen back all im getting is static this is not the only time this has happened why am i getting static on my recordings
bob550
Albany County, NY
What frequencies are you recording? What scanner are you using? Are you searching a range of frequencies or scanning individual frequencies?
stuart3009
I’m using sdr sharp scanner I was just scanning through military this is the 2nd time it’s happened I can listen to what they are saying but when I play it back all I get is static
Using the SDR/Airspy, this question might get better responses in the SDR Forum rather than general scanning. Some people with knowledge to best answer your concerns may only monitor certain threads.
Please click on REPORT in the lower left corner of your post and ask for this to be moved, don't start a new thread as double posting is discouraged in the forums.
stuart3009
Thanks I’ve just done it
dickie757
Wired
Out of range
How are you recording it? I did a recording that had about 1.4 MHz bandwidth as a raw recording, and it clocked in at 2 GB for 15 seconds worth of data. Roughly 135 MB/s bitrate. What I'm getting at....while in playback mode, I could tune to any part of the 1.4 MHz bandwidth, static or signal, and do anything I wanted, just like it was live.
More info needed on the recording method please.
dickie757
Wired
Out of range
Edit...my recordings are .wav files. When played back in a music player, they are nithing but static. Try replaying them in SDR # or Console
stuart3009
im recording it via the audio recorder on sdr sharp and my dispay is set at 4.8mhz my frequency scanner is scanning at 130-150 bandwith 18,000 and step 20,000
Fredo68
You're talking about baseband recordings. I think the OP was talking about audio recordings
stuart3009
yes im on about basband recordings ive con my audio recorder i can hear when im scanning but when i pay back all i get is static
Fredo68
You want to record audio when playing back baseband recordings? I'm not sure I'm understanding what you want to do.
stuart3009
So when I listening to aircraft broadcasting I want to record it I’ve done it before but when I play back what I’ve recorded all
I get is static
Fredo68
I get is static
Sorry but that explains nothing we didn't already know. You say you are using the audio recorder but say you're "on about" baseband recordings. Which one is it?
Both produce very different .wav files which aren't interchangeable between baseband and audio.
To get any further, you'll need to explain exactly what you are doing.
stuart3009
Ok so I’m scanning the airwaves for aircraft traffic when I hear conversations the audio recorder records what has been said but when I play it back I’m not getting anything is there something I’m doing wrong have I got wrong recorder
Fredo68
That seems to be the right recorder to use. I just recorded some AM Airband traffic and it plays back fine. I can't replicate the scanning here so as an experiment; find an active frequency and record it - no scanning. See how the playback is and report back.
What makes you certain the audio recorder is recording when there's nothing heard on play back?
We need to break this down to find the problem. ETA it might help if you could explain where baseband recording comes into this.
stuart3009
stuart3009
You do have a point lol how do I know it’s recording the problem with sdr sharp is that it has 2 recorders and perhaps I’m using the wrong one I’m using audio recorder there is a person on YouTube who I watched go get it working
Fredo68
audio recorder records audio. baseband recorder records the current RF spectrum - it's basically recording the actual radio signals not audio.
Looks like you want audio so you're using the right recorder. I was confused by your comment that you were on about baseband recording.
Record one signal and let us know. It will hopefully narrow problem solving to the scanner part
