Toggling the Status Bit
Motorola talkgroup ID’s are sent as a 16-bit binary number. Normally, the last 4 positions in
the number are 0’s, which result in all talkgroups being equally divisible by 16. These last
four bits, however, can be used by the trunking system to indicate various status conditions.
For example, an emergency status could be indicated by setting the second-from last digit to
1. Talkgroup 33264, then would be sent on the system as 33266 when the radio triggered its
emergency status. By default, the BC796D ignores the last four digits of every talkgroup,
effectively rounding them down to the nearest multiple of 16 regardless of the status bits.
2:SCAN OPTION → 2:TRUNK → Select the bank → 0:STATUS BIT
1:ON
Talkgroups are rounded down to the next multiple of 16.
2:OFF
Talkgroups are not rounded down, so you can determine the value of the status
bits.
