Stealth Scanner Antennas
Washington State
An octogenarian friend of mine was forced, due to health reasons, to move into a senior condominium complex that has some highly restrictive HOAs. One of the restrictions is, "NO EXTERNAL ANTENNAS ALLOWED". He does however have a small private patio and wants to hook his HP2 up to a "stealth antenna". William does not have, "that newfangled Internet", so I offered to look for him, but there are so many to choose from. I don't want him to get a P.O.S. for an antenna, so I'm looking to the experts here to recommend one that you know will give him decent results. Suggestions? Thanks.
popnokick
Northeast PA
The wire version of this antenna is very inexpensive, easy to put together, and easily hidden from view - even when in the same room / area as the antenna. Hang it in a window behind a curtain or blind, or even better hang in corner of patio outside. (Scroll down the page below the copper pipe version to see the wire version) -
Homebrewed Off-Center Fed Dipole - The RadioReference Wiki
Washington State
It would help a lot if you state what your friend wants to listen to.
He pretty much listens to everything from 145.00 MHz up into the 800Mhz range. Basically Amateur Radio chit chat, police, fire, ambulance, state patrol, you name it.
Washington State
Thanks I'll file this away, not exactly stealthy but I might be able to run it down alongside his sliding door trim and paint it to match if nothing else turns up.
popnokick
Northeast PA
You must not have scrolled down the landing page for the OCFD to see the "wire only" version. The copper pipe version is at the top of the webpage and to see the wire / stealth version YOU NEED TO SCROLL DOWN THE PAGE.
trentbob
Silent Key W3BUX
Bucks County, PA
He can always hang a flower pot with a sparse plant or flowers that can camouflage a mini discone or a VHF High, Uhf, 800 MHz ground plane.
Hopefully if there's any problem he can tell the HOA to go pound sand like so many others do.
If they really take action against him and hurt him in any way he should seek out local media for a nice colorful human interest story. "Lonely man denied his Hobby" with a picture of him and the lovely flower pot.😆
trentbob
Silent Key W3BUX
Bucks County, PA
Of course there's always the option of getting an inexpensive floor lamp at Walmart where there's a good selection and mounting a mini discone or a tri band ground plane near a window.
consys
Carmichael, CA
One of the best broadband receive antennas I ever used was the aluminum window frame next to my desk in a group office. A short coax to an alligator clip. It went in my desk drawer when the bosses hung around. Before I got the window seat I used a file cabinet, worked but not as good. Everything is an antenna, some things better than others. You never know until you try.
cbehr91
I would recommend the COMPACTenna SCAN-III out on that balcony.
wtp
Port Charlotte FL
does he really NEED the bigger antenna.
if it is a local system and local hams,
a back of the set might work.
iMONITOR
Silent Key
S.E. Michigan
A potted plant with a small vertical hidden along side a fake plant? Put a metal cookie sheet under the pot connected to the shield of the coax.
shopping
Washington State
This is one of the two I like. It's in his price range and easy to build. I'll show him this one.
Sadly this is out of his price range, he spent almost everything he had on the condo and is now living off of his social security.
I like this one too! It would be easy to hide an antenna in a fake plant like that. I'm going to show him this one too.
Thanks guys you've been a big help!
k4fv
Dania Beach, FL
I’ve found a good quality antenna connected directly to the scanner can work very well. I own the one referenced below. It is designed for VHF and UHF and gives good results on 800mhz.
Washington State
You know I mentioned the SMA-W100RX to him because of the elbow and it would work on the side of his HP2. Apparently he does not like the idea of an antenna interfering with the lamp shade next to his chair or putting undue stress on the antenna connector. I offered to give him the antenna that came with my RTL-SDR, but he's adamant about an outdoor antenna. It's not like 1/4 inch of glass will make a difference, but what can you do.
