mdmonitor
Guys,
1120- Rider 70 (C-17) doing patterns at BWI. BWI tower controller said " that was the sweetest, fantastic touch & go" he'd ever seen.
Rider 70 said' we call that a GOAT Go Around and Touch" and asked if he wanted to see another one & the tower quickly said "Yes Please"
freqhopping
Guys,
I guess he's going to check out Dulles now.
Going to do 2 or 3 ILS and some overhead. Says he has some United Airbus guys onboard.
I've got a new TRAM 1410 discone up now, mounted on the roof. I've gotten better reception without an amp than I do with an amp on my DPD LP in my attic.
No issues seeing RIDER70 bank to the right on the climb out.
freqhopping
RIDER70 giving Dulles a little show. I don't think ever seen anything do a midfield break over the top at Dulles.
1243- One more 1R approach with a left break. Then back to Dover.
Actually another 1R approach with the option. Waiting on their IFR clearance back to Dover.
Tech792
Central NJ
I use to have a Tram 1410 and then I swapped it out for an Antenna Specialists MON-58 ground plane since I always used AS antennas over the years. At the same height on the mast. The Tram performed better. I'm thinking of switching it back. I also had the Scantenna years ago which did very well but the elements would break after a while.
mdmonitor
1915- Couple of 121st F-16s working in the PAX areas . No calls noted yet.
Working w/Bay Watch (305.2) & on discrete (238.175)
Ravage is callsign. Haven't heard them use that one in awhile. Working Close Air Support on ground targets.
Rare one tonight mode s out of Dover from Chile.
(E80675) FACH912 climbing up and into Miami fast in 2.5 hours.
Not sure what type business jets the Chile Air Force uses but a Gulfstream IV has been seen using FACH912 callsign.
Found Vid of 912.. It is a GLF4
Day trip tomorrow for AF1, departing @ 12:20pm enroute to Lehigh Valley International Airport (ABE) a domestic airport in Hanover Township, Lehigh County, Pennsylvania. Return scheduled for 3:30pm. Lately he's been running 20-30 minutes late.
BM82557
Berkeley Co WV
freqhopping
Got some action on 326.4, the freq used by A-10s working at Quantico for training ops.
Hearing EMPIRE and GUNNY1. Going to take a quick break to put on NVGs.
mdmonitor
Logs 13 May
ADW: ((A/D 118.95/257.2, 125.65/348.725, tower 118.4/349.0))
.0840- Marine 374 (UC-35 # 166374 AE0940 VMR-4) off of ADW heading south. ADS-B carrying callsign as Atila-25. Returns at 1955.Came in from Atlanta GA.
1915- Ravage flt (2 X F-16s 121st FS DC ANG) working Close Air Support (CAS) on ground targets w/BW (305.2) & on discrete (238.175), Ravage flt also AAR w/DeeCee 32 (KC-135R # 61-0367 AE049A 756th ARS)
1945- SAM 691 (C-37 # 97-0401 AE010E 89th AS) land at ADW. Came in from Victorville CA.
PAX: ((A/D 120.05/121.0/250.3/281.8/314.0 Bay Watch 119.275/256.5/270.8/305.2/354.8/355.8))
0955- Tester 11 (T-38C # 688158 AE1393 NTPS) report completion of speed run: Mach 1.09 at FL330.
1330- Score 50 (C-130 # 162310 AE03C4 VX-20) depart PAX and pattern work at Martinsburg WVA.
DOV: ((A/D 132.425/287.525 tower 126.35/279.625 CP 349.4))
1105- Rider 75 (C-17 # 07-7170 AE1468 3rd AS) off DOV for pattern work at BWI (119.7 & 119.4). After 1/2 hour of patterns heads down to Dulles for some work. Returned to DOV at 1415.
1935- Jumbo 71 (C-5M # 85-0008 AE0565 9th AS) off Dov heading east. Calling unid acft on AR777 primary (315.9)
OTHER:
0825- Toxic 62 (C-12 # 96-00112 ADFF00 US Army Chemical & Biological Command, Aberdeen Proving Grounds MD) depart Phillips AAF heading west. Check in w/ZDC Linden (133.55).
0940- Coast Guard 101 (C-37 # 101 AE10C1 CGAS Wash DCA) depart DCA heading northwest. Check in w/ZDC Hagerstown (134.15). Usually the Commandant's acft. Returned to DCA at 1230. Came in from Ohio.
1145- Castle 57 (C-130 # 90-1057 AE02F2 143rd AS DE ANG New Castle) depart New Castle for pattern work at Harrisburg/Lancaster. Off of New Castle at 2000 for local ops at ACY.
