Sticky Thread For Mid-Atlantic MilAir 2021
mdmonitor
I know some you are interested in HF so passing th is along.
Over the last day or so the TACAMOs & ABNCPs have been sending their EAMs on 10805.0 USB & 11081.2 USB. This is in addition to the regular HF-GCS freqs.
jetcrafter
Southern Maine
Ed,
I have 355.000 for Foxtrot Primary. Has it changed?
I'm assuming 234.600 and 231.000 must be frequencies from overseas as I don't see them listed as Coronet freqs.
Jared,
I have 355.0 listed as LANT F PRI as well but no prefix number. A friend of mine and I have logged 356.8 as 61 F LANT PRI dating back to 2013. Not used too much but it pops up once in awhile. You had me questioning if it was correct but it was being used by a TREND "61" flight as their boom freq which makes me thing the number prefix is correct on it. Your thoughts?
I had 234.6 as a NORAD freq. I found 231.0 using search and have no information about it's use. Sorry.
mdmonitor
1300- Litt-52 (E-6B # 164387 AE0414 VQ-4 Det) off PAX heading west. Working ZDC Montebello (121.675) requesting to remain on original flt route. Working Montebello using callsign Iron 28 so maybe going back to Tinker? Still showing Litt-52 on ADS-B.
1325- Ascot 6660 (RAF C-17 ZZ178 99th Sqdn RAF Brize Norton) transiting area from north to south at FL360. Working ZDC Pinion (133.975)
jsoergel
Cincinnati/Dayton, OH
Jared,
Can't say I've seen a log of 355.000 in the past, but I do see 356.800 listed in Europe as an AR frequency. I think you are likely correct, and it raises the question of whether or not the other Atlantic AR freqs I have are accurate.
AirScan
13:10 EST - IDOL 12 cleared RTB via direct IHD then requesting IIU direct KBAD at FL250.
13:18 EST - re-cleared direct KBAD.
jetcrafter
Southern Maine
Jared, I question myself and the freqs I have for Coronet all the time. I try to keep a file of what and when these freqs are used to help me weed out very old unused freqs. Unfortunately, I find myself keeping old freqs. There are a few above the 380 MHz range that are still used quite often for Coronets and to just assume that because they changed the band plan to stop at 380 MHz doesn't mean squat here. With the Atlantic and Euro freqs, there are a whole bunch not heard or seen on this side of the pond that I can't confirm. I can't recall hearing 355.0 either but you just never know. Some freqs only get used once in awhile and then are quiet for a time and then a year or two later....they use them! Coronet chasing is very frustrating and it seems like more luck when I catch new ones!
jetcrafter
Southern Maine
1912z
KBAD BUFF, IDOL 12 inbound returning air spare checking in with ZBW switched from 269.3 to 307.9 FL240.
SPUR 82 flight doing random AR amongst themselves on their way back to McGuire using 268.025 for their a2a refueling comms. Currently on ZBW 133.45 "82 has the lead".
freqhopping
Last night I caught a 56-character message on 11175, likely from E-6B 163919. I think the callsign was BIRDTRAP. BIRD-something.
1448 IDOL-12 on ZNY Elmira High 298.900 push something 025.
1503 Short coms on 270.250 blocking 26-27.
1504 IDOL-12 on ZNY 346.275 ZNY High.
1507 IDOL-12 checking in Cleveland Ctr Altoona 363.075 no joy after 3 attempts.
1509 IDOL -12 back on 346.275 "push 256.400" Lost him after that.maybe incorrect read by me.Assume SW near Pittsburgh by now.
freqhopping
5th BW A>A - 300.225
5th BW 23rd BS A>A - 310.250
5th BW 23rd BS A>A - 307.950
5th BW A>A - 381.650
5th BW A>A - 390.575
5th BW A>A - 265.125
5th BW A>A - 300.525
5th BW Ops Fortress Control - 249.975
Some others I don't have associated to a unit.
B-52 A>A - 298.900
B-52 A>A - 225.725
B-52 A>A - 343.675
B-52 A>A - 256.275
B-52 A>A - 295.000
B-2 - 318.050
B-2 509th BW Ch33 - 300.100
B-2 509th BW Ch39 - 327.600
B-2 509th BW Ch69 - 388.850
B-2 509th BW Ch9 - 381.300
B-2 509th BW Ch94 - 316.900
B-2 Batt Ops 509th BW - 280.150
B2 flyover - 260.250
B2 flyover - 320.525
B2 flyover - 265.825
B2 flyover - 354.350
B2 flyover - 257.100
B-2 flyover - 233.025
B-2 flyover - 370.900
B-2 flyover - 290.225
AirScan
They are over the Med now --
21:13 EST - IDOL 11 checking on with Malta Radar approaching waypoint VENIM at FL270-FL280 cleared flight planned route (LMML LiveATC). They are showing up on FR24 but not ADSB-X.
rjsincs
On Planeradar.ru it was showing the Idol flight getting cozy with a Russian Military Il-62 over Malta. Could have been hundreds of miles apart but it sure looked interesting.
