STLCO SLATER
llzel
St Louis, MO
who does muni fire dispatch for?
54751d5dfDMuni Fire DispMuni Fire: Dispatch M [M DISP F]
bdzig
Manchester, Missouri
It is used by Kirkwood to dispatch Kirkwood, Glendale, and Des Peres Fire Departments. They respond on Kirkwood Main (54749) and use Tac 50-59 for major assignments.
llzel
St Louis, MO
Thanks Is Ladue 54750 for dispatch and response? I have 54750 programmed for Ladue but hear nothing.
nick1427d
IL
Ladue is dispatched by central county 911 on south dispatch. Unit numbers 39xx.
Ladue fire talkgroup is old from when they were self dispatched.
jimsearles
Grasonville, MD
I am having trouble getting reception of South Fire: Main S [S MAIN F] and South Fire: Dispatch S [S DISP F] where I live near Chesterfield Mall.
Any tips?
I am using a HomePatrol2.
thanks!
kruser
Well Known Member
W St Louis Cnty, MO
Hi all- how can I tell which tower I am receiving?
For a simulcast system, there's no way to tell which physical tower site you are receiving. All sites on a system broadcast identical data.
You can tell which system you are receiving by the site number displayed. Hold on the control channel and the display should alternate between active talkgroups and the system ID info.
For STL County, you would ideally want Slater South or site 1-2 but near your location, you may get better results from the nouth site 1-1.
Slater can be tricky out this way as we have both south and north site towers which can cause severe simulcast issues.
For fire, most fire traffic for Monarch will be heard on south and north but the south system would be the primary system as Monarch FPD is located south of Page which is the dividing line between the two Slater systems.
If you can see the frequency while there is no voice traffic, 853.825 would be site 1-1 North and 853.7875 would be site 1-2 South. That will change when a voice channel goes active though.
I'm also not exactly positive how the HP-2 displays the info but if you created a favorites list for Slater in your HP-2, it should be easy to toggle each system on or off.
You may also want to look into the hidden menu option under the audio tab and put the P25 setting into manual mode with a level of 6. That's definitely needed if I use my old HP-1. The only problem is that it reverts back to Auto each time you power cycle the scanner.
Do a google search on HP-1 or 2 hidden menu and you should find the info on which firmware you need and then how to make the adjustments.
I thought I recall that Uniden may have made it a little easier to change the P25 setting in the HP-2 model but I could be thinking of something else.
There was also the Analyze functions that could be very handy for getting site and system info.
That feature was part of the optional paid Extreme Upgrade for the HP-1 but I don't know if it was also optional in the HP-2 or if Uniden included the Extreme features in the HP-2 model.
VASCAR2
So Illinois
Sometimes you get simulcast systems if your very close to an individual site that can over power the other sites in a simulcast system if your not using an SDS 100/200 scanner. This link gives you the location of each simulcast site in north ST Louis County. Knowing the physical location of each site makes it easier to understand why you might have better reception at one place than at other locations. Any terrain features can have an effect on reception is in a particular location. Normally 700/800 signals are degraded in summer months due to foliage.
marksroberson
Florida Panhandle
Good afternoon folks, I don't live anywhere close to you guys but I have some information, This was the only forum post with SLATER info in it. I am ONLY adding info not currently in the DB. Here is some Info that I have:
RFSSSite IDName
11-1SLCNTY NORTH
12-2SLCNTY SOUTH
13-3ST CHARLES
14-4JEFFCO-N
15-5JEFFCO-S
16-6ACC-ASR
126-1AWASH U
For the TGs:
32CFOEM 5
32D0OEM 6
32D1OEM 7
32D2OEM 8
32D3OEM 9
64SLR IO1
6DSLR IO 10
6ESLR IO 11
6FSLR IO 12
65SLR IO 2
66SLR IO 3
67SLR IO 4
68SLR IO 5
69SLR IO 6
6ASLR IO 7
6BSLR IO 8
6CSLR IO 9
70SLR SWAT (ENCRYPTED)
D833SLC ENC 1 (ENCRYPTED)
D834SLC ENC 2 (ENCRYPTED)
D835SLC ENC 3 (ENCRYPTED)
D836SLC ENC 4 (ENCRYPTED)
D837SLC ENC 5 (ENCRYPTED)
D838SLC ENC 6 (ENCRYPTED)
D839SLC ENC 7 (ENCRYPTED)
D83ASLC ENC 8 (ENCRYPTED)
D991SLC ENC 9 (ENCRYPTED)
D992SLC ENC 10 (ENCRYPTED)
D993SLC ENC 11 (ENCRYPTED)
D994SLC ENC 12 (ENCRYPTED)
E28BSLC ENC 13 (ENCRYPTED)
E28CSLC ENC 14 (ENCRYPTED)
E28DSLC ENC 15 (ENCRYPTED)
E28ESLC ENC 16 (ENCRYPTED)
112"MODOTRSA"
113RED CROSS
114SALVATION ARMY
115UNITED WAY
5BF4"SCCEMD"
5BF6"SCCEMVOL"
D815"CDOJ C" DEPARTMENT OF JUSTICE
D860SLCDOJ 3
D25CH/S ADMIN (HOMELAND SECURITY?)
D25DH/S ALL
D25EH/S EOC
D25FH/S FSIS
D260H/S HS
D261H/S OFCS
D262H/S RS
D263H/S WD
D23FSLC GOV
D19FSLC PARKS 3
D1A0SLC PARKS 4
D244SLC PK GAR (PARKS GARBAGE?)
D85B"SECSVR1"
D161ALL HIGHWAY
D160ALL PUBLIC WORKS
D180CO PW ADMIN
D186CO PW FACILITIES
D185CO PW DISPATCH
D21BHWY ADMIN
D193HWY DISP
D1A3PLAN REV
D259SLC 1050
D241SLC SRVA
D242SLC SRVB
D25ASLC STPA
D25BSLC STPB
D243SLC TOB
D1AASLC TRAFFIC CONTROL
D16ASLC CONSTRUCTION
D194SLC FLEET
D19ASLCN SAT
D169SLCS SAT
D168SLCW SAT
D1A5SPC SVC
D85CSHERIFF? (ENCRYPTED)
D81BSLC DEP1 (ENCRYPTED)
D81CSLC DEP2 (ENCRYPTED)
D804SLC BAIL 1 (ENCRYPTED)
D805SLC BAIL 2 (ENCRYPTED)
D98BCO PD ADMIN 1 (ENCRYPTED)
D98CCO PD ADMIN 2 (ENCRYPTED)
D930DCI 1 (ENCRYPTED)
D987FED IO 2 (ENCRYPTED)
D931DCI 2 (ENCRYPTED)
D932DCI 3 (ENCRYPTED)
D933DCI 4 (ENCRYPTED)
D934DCI 5 (ENCRYPTED)
D935DCI 6 (ENCRYPTED)
D988DCI 7 (ENCRYPTED)
D989DCI 8 (ENCRYPTED)
D98AFED IO 1 (ENCRYPTED)
D936"SLCPDSUP" (ENCRYPTED)
D937DCI ENF 1 (ENCRYPTED)
D938DCI ENF 2 (ENCRYPTED)
D939DCI ENF 3 (ENCRYPTED)
D93ADCI ENF 4 (ENCRYPTED)
D93BDCI ENF 5 (ENCRYPTED)
D93CDCI ENF 6 (ENCRYPTED)
D93DDCI ENF 7 (ENCRYPTED)
D93EDRG 1 (DRUG TASKFORCE?) (ENCRYPTED)
D93FDRG 2 (ENCRYPTED)
D940DRG 3 (ENCRYPTED)
D941DRG 4 (ENCRYPTED)
D942DRG 5 (ENCRYPTED)
D943DRG 6 (ENCRYPTED)
D953INTEL 1 (ENCRYPTED)
D954INTEL 2 (ENCRYPTED)
D944OPS ENF 1 (ENCRYPTED)
CF09SLCDATA1
CF0ASLC DATA2
CF0BSLCDATA3
D6D8MC ADM
D6D9SCEUCADM
D6DBSLCC ADM
D1ACUMSL ALL
D1ADUMSL PW
D1AEUMSLSHUT
D258WSU ALL
D6DAWW ADM
D837LEOSLC1
D838LEOSLC2
D839LEOSLC3
D83ALEOSLC4
D84AMUENF J
D84BMU ENF K
D842NMUENFB
D843NMUENFC
D844NMUENFD
D845SMUENFA
D846SMUENF B
D847SMUENF C
D848SMUENF D
D849SLC LAW 1 (ENCRYPTED)
D98ESLC LAW 2 (ENCRYPTED)
D98FSLC LAW 3 (ENCRYPTED)
D84CSLC LAW 4 (ENCRYPTED)
D84DSLC LAW 5 (ENCRYPTED)
D84ESLC LAW 6 (ENCRYPTED)
D84FSLC LAW 7 (ENCRYPTED)
D850SLC LAW 8 (ENCRYPTED)
D841SLC LAW 9 (ENCRYPTED)
D357SLCOEM10
D358SLCOEM11
D359SLCOEM12
D35BSLCOEM14
D35CSLCOEM15
D367SLCOEM17
D35DSLCOEM16
D368SLCOEM18
D369SLCOEM19
D36ASLCOEM20
D36BSLCOEM21
D36DSLCOEM23
D36CSLCOEM22
D36ESLCOEM24
D36FSLCOEM25
D370SLCOEM26
D371SLCOEM27
D372SLCOEM28
D373SLCOEM29
D6DDSHR ADM
D80FBRW PD (ENCRYPTED)
D818CRE DET (ENCRYPTED)
D82EJEN JAIL (ENCRYPTED)
D81ACW PT PT (POINT TO POINT?)
D85ASCEUC 1 (ENCRYPTED)
D828SLCCPDN (ENCRYPTED)
D83CSLCCPDS (ENCRYPTED)
D86DSUNSET HILLS ALT (ENCRYPTED)
D875"WC C C" (WEST COUNTY) (ENCRYPTED)
D87DWSU ERG (EMERGENCY?) (ENCRYPTED)
D87EWSU SP (ENCRYPTED)
D87FWSU TAC (ENCRYPTED)
D880WW DISP (ENCRYPTED)
D956BAL SUPPORT (ENCRYPTED)
D958BLR SUPPORT (ENCRYPTED)
D95ABRH SUPPORT (ENCRYPTED)
D95BBRK SUPPORT (ENCRYPTED)
D95DCCR SUPPORT (ENCRYPTED)
D95ECHF SUPPORT (ENCRYPTED)
D962EUR SUPPORT (ENCRYPTED)
D968HLD SUPPORT (ENCRYPTED)
D96BMAN SUPPORT (ENCRYPTED)
D96DMOL SUPPORT (ENCRYPTED)
And that's all folks! Spent half my Saturday typing this out. obviously, all TGIDs are HEX.
I am NOT submitting these, I am leaving them with you all to listen to and submit as they come along. I am sorry but you will have to work with the abbreviations given to me. If you have any questions, feel free to DM me or reach out on the forum here. Happy Monitoring!
llzel
St Louis, MO
I didn't know wash u had a tower and not sure where ↓↓↓↓↓ is located
16-6ACC-ASR
