stolpskyltar
lindasim100
Banned
In general practice, batch process and jobbing processes can be similar, but the batch processes have less variety compared with the jobbing processes. As the term batch indicates, the output of each process will make more than one piece of the product. In the manufacturing line, each single operation has its own repeatable part. The skylt & dekor individual operation is repeating itself during the batch production. If the size of the batch is small, only two or three pieces, the batch processes will be nearly the same as the jobbing processes. This is normally in the case of a new product. However, if the batch size is large, and the products are frequently manufactured on the production lines, the batch processes can be repetitive. Therefore, the batch processes can support a wider range of volume and variety, compared with other processes. Take an LED bulb manufacturer for example. The manufacturing of the T12 LED tube light and T8 LED tube light can be batch processes, and the size will be large.
