Hello to the community.
I'm facing a strange issue, and I need your support and experience.
I’m a radio amateur and I have recently purchased a used DM2600 mobile DMR Motorola Mototrbo radio that I have successfully programmed with CPS 2.0 to some mainly digital repeaters adding a few talk groups.
The radio works as it should and have also made some contacts.
The only annoying issue I have is that the red led is blinking (since I bought it) with a rate of one blink per second approximately.
I have checked in the manual where it is mentioned that this led blinks when radio receives an emergency transmission, or auto range feature on analogue channels is enabled (ARTS), or there is a failed self-test however for the first two everything is disabled and for the case of a failed self-test I get no recorded or instant alarm throughout the boot cycle of the radio operation and no alarms on the radio’s display!
I have also tried to delete my roaming channels and roaming list and I have not configured any scanning list and all scanning is disabled.
Any experience with such a behaviour?
I can provide views of the code-plug if required.
Thanks in advance for any relevant suggestion.
