Strange / annoying signal on 27.385 LSB?
kc2asb
NYC Area
Strange sounds are far from unheard of on CB. That being said, at my location, I am hearing what can only be described as a screeching/wailing sound on this channel. I do not hear it in USB. I also checked two Kiwi SDRs (Cape Cod and Maryland) and I'm hearing it there too, so it's not a local signal. Has anyone else heard this / know what it is? I enjoy monitoring 385 but this is really hard to listen to for more than a couple of minutes.
kc2asb
NYC Area
17:00 UTC... Seems I'm hearing it here in Manitoba, Canada. Screeches along with music playing.. Strong signal.. S9. Just stopped.. Some goof playing around.
That is the signal. It's not just today - it has been there at least a couple of weeks whenever the band is open, and it is a constant signal.
kc2asb
NYC Area
Strange noises on 38 lsb? Just business as usual. Try 27.425 for a different flavor of insanity.
True enough. Almost 35 years on/off the CB bands, I've heard a lot. This one just stood out because of the constant presence and being heard over a multi-day period. Hopefully this individual is not reading this forum and sees this as his claim to fame. :D
merlin
DN32su
Still not as bad as the old days when it took a high end receiver to tune a desired channel and then, competing with the garbage on channel 6.
That took power and a directional antenna.
You get 500 cbers keyed down you get hetrodyne squeal, and SSB any carrier will hetrodyne with the BFO.
kc2asb
NYC Area
True, but a hetrodyne squeal is a musical masterpiece compared to this. :)
slowmover
Fort Worth
Sez the magician had him some good-looking help in putting together, “oh, just an amp”
