BCD436HP/BCD536HP: Strange display when playback recordings
RichardKramer
Reading, PA
This showed up in the display hits when playing back a days recordings.
I was recording programmed freqs from my Fedcomm favorite lists. All the programmed freqs in the lists are between 162-174MHz & 406-420MhZ.
It's happened several times on different recording sessions.20260507_113928.jpg
RichardKramer
Reading, PA
My guess would be a corrupted SD card and judging by the looks of the case I'm not surprised.
All the scanner functions are fine; it's a sloppy job of super glue put on where the display cover was coming loose; the other mess on the left upper side is hot glue where I added an additional speaker jack to get full volume out of my lapel speaker/mobile speakers because Uniden has to limit the audio output on the internal earphone jack so no one "blows their ears out "- lol.
What does the look of the case have to do with a corrupted sd card???
RichardKramer
Reading, PA
My other 436 had a similar display when recording the same Favorites list. Maybe the looks of that case caused the sd card to be corrupted too??20260507_133125.jpg
richardbritt
State of NC
Northeastern NC
Looks like the scanner didn't know where the upper and lower frequency limits were supposed to be, possible bad SD card? Maybe reload the firmware because it's corrupted and/or replace the SD card
RichardKramer
Reading, PA
Everything is working fine. This display is paused on the 4th hit during playback. The other 99 hits were recorded ok. I haven't had any issues with the sd card during any opeation of the scanner. Updates work fine, no problem loading new fav lists or any other issues. In the past year have noticed this hit in the display about 4 times during a playback of my Fedcomm favorites list after recording for the day. It hasn't shown up in any other Fav lists recordings, just in the Fedcomm fav list.
