I'm currently streaming a private feed from a BCD996P2 using ProScan. My laptop doesn't have a microphone input jack, so I'm using a USB mic adapter (works great). I'd like to stream a second feed from my BCT15X using the same computer with a second USB mic adapter. I've installed the second adapter, and the laptop recognizes it. I can assign each USB mic to its respective scanner in the Windows sound settings. I can see the separate audio signals being captured by each. However, it appears that I can't stream audio from the two mics independently. I'm stuck using one or the other.
Do I need a separate computer sound card to manage the audio for the second stream, or is there a way that Windows will allow me to use the two mics at the same time?
