Suffolk Fire Channels
kainixon2187
Virginia Beach, Virginia
Im currently looking at the channel plan for VB and under the two Suffolk Fire zones the channels are listed like this:
But on the DB, they're listed like this:
Would "SFR Fire 2" be "3 FIRE TAC 2" or would "SFR Tac 1" be "3 FIRE TAC 2?"
Webodisk
Silent key.
Virginia Beach,VA
the beach template should have changed, they just did an OTA reprogram removing all the analog system Tg's and possibly adjusting that template
clbsquared
Isle of Wight County
The names of Suffolk talkgroups have changed. They are no longer using Fire 1,2,3 etc. They are now listed as TAC 1, 2, 3, etc. The RR database for Suffolk/Isle of Wight hasn’t been updated since they changed the names earlier this year.
jkahn
Very good looking Member
Silver Spring MD
For the OP's benefit
kainixon2187
the channel plan does not list talkgroup IDs for the channels, so you are trying to compare apples to oranges
LeSueurC
Virginia Beach, VA
Fire 2-Fire 5 are now Tac 2-Tac 5, the way I have it setup is TG 1053 as Fire Tac 6 and so on down to Tac 8. That leaves one channel out Tac 15, the last channel I have is TG 1061 as Tac 14
kainixon2187
Thank you for all the replies! I would assume Tac 15 is used rarely so it'll probably be difficult to find. I remember seeing a thread or message on here saying that the channels got updated like this, I just wasn't sure.
kainixon2187
This is slightly off-topic, but when removing the smartnet talkgroups off the radios did event 1 just move to channel 7 on the vb emergency management zone, or did they just replace channels 7 through 12 with something else and kept event 1 on 13?
