bsavery said:
scanfan03 said:
Any 800MHz system is going to have to be rebanded.
Not "Any system"... there are some that will require no changes at all.
For example... the Sarpy Co system I primarily monitor has 20 channels. 14 of them require no change, and the other 6 are in the expansion band and do not have to change if they don't wish.
The hospital I work at doesn't have to change frequencies either.
Okay, I think this is an excellent time to point out some things.
Whereas the
Sarpy County Public Safety System does not change frequencies, nobody in this rebanding gets away
Scott-Free. They are being rebanded, although it is only for channel changes. Take for example the lowest frequency channel on the system at this point, 856.2375. That is presently channel 210, after rebanding that is channel 320. So this requires reprogramming of all radios and of course your scanner will no longer work properly unless you upgrade (if possible) or reprogram it (if possible.) BTW, Sarpy County is in the 2nd wave of rebanding which according to the FCC schedule should start in 2006, 3rd Qtr.
So, all of you out there who are considering yourself lucky that your favorite system isn't going to change are just not understanding the rebanding issue properly.
All 800MHz trunking systems will be affected to some extent by this.
