Here are some observations and analysis on how DSDPlus handles
the Sumter Electric Cooperative Tier 3 system.
Sumter Electric Cooperative Mount Dora site 857.5875
16 bit SysCode=00.000000000.100 AB
Tiny network can have 512 networks with 8 sites per network.
00 for Tiny network 000000000 for network number 1 (0+1)
100 for site 5 (4+1) with 000 as site 1 and 111 as site 8.
If the areaLength parameter is set to 0 in DSDPlus.networks
protocol, networkID, "network name"[, TIIIareaLength]
TIII, 1, "Sumter Electric Cooperative", 0
then DSDPlus shows it as T1-1.5 DCC:0
Tiny network 1, area 1, site 5.
However, DSDPlus appears to default the area parameter to 2
when it is not specified in the DSDPlus.networks file.
Then DSDPlus reports it as T1-3.1 instead of T1-1.5
Here is an analysis of how this apparently works.
With the area parameter set to 2 the area.site is calculated as
using the first 2 bits of 100 for the area which is 10
which is 3=2+1. It then uses the remaining bit which is 0
as the site 1=0+1 which gives the 3.1.
With the area parameter set to 0 the area.site is calculated as
using no bits for the area which then defaults to area = 1
and then all three bits of 100 are used for the site 5=4+1
yielding 1.5.
For the Groveland site on 855.8375
16 bit SysCode=00.000000000.011 AB
With the areaLength parameter set to 2 it shows as T1-2.2
which is 01 for 2=1+1 for the area and then the
remaining bit 1 for 2=1+1 for site.
With the areaLength parameter set to 0 it shows as
T1-1.4 which is default area of 1 and site is 011 for 4=3+1.
Then DSDPlus.sites may have
TIII, 1, 1.4, "Groveland"
TIII, 1, 1.5, "Mount Dora"
and DSDPlus.frequencies may have
TIII, 1, 1.4, 15, 855.83750, 0.0, 0
TIII, 1, 1.4, 17, 859.31250, 0.0, 0
TIII, 1, 1.4, 19, 855.76250, 0.0, 0
TIII, 1, 1.5, 21, 857.58750, 0.0, 0
TIII, 1, 1.5, 23, 859.06250, 0.0, 0
TIII, 1, 1.5, 25, 860.41250, 0.0, 0
The AB PARtition parameter in the last two bits of the
16 bit syscode indicates that category A and B mobile stations
are permitted and would be represented in the syscode as 11.
01 is for category A only and 10 is for category B only.
More information can be found in
ETSI TS 102 361-4 which is Part 4: DMR trunking protocol.
Here is a guess for the sites and their control channels in
this system as it seems reasonable to view this Tiny system
as having one area with 8 sites:
area.site control channel location
1.1 856.9125 Summerfield WRER661
1.2
1.3 857.4125 Sumterville WRER661
1.4 855.8375 Groveland WRER661
1.5 857.5875 Mount Dora WRER661
1.6 857.8125 Inverness WRER661
1.7 854.7125 Dunnellon also 855.0625 WRFW904
1.8 860.6375 Umatilla WRER661
The following sites do not appear to be active.
Clermont WRFW904 855.6500 856.4000 859.3750 860.4000 pending
Deland WRFL554 854.6125 860.2875
Ocala is being deleted from WRFL554
