Sumter Electric Cooperative DMR TIII
bravo14
Polk County FL
For the sds100/200 vs dsdplus sites. DSDPlus displays region area site where sds shows site number.
Dsdplus / SDS
Region Area.Site / SDS site
1 2.1 Sumterview / SDS shows 2
1 2.2 Groveland / SDS shows 3
1 3.1 Mount Dora / SDS shows 4
1 3.2 Inverness / SDS shows 5
1 4.1 Dunnellon/ SDS Shows 6
1 4.2 Umatilla / SDS shows 7
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
Dsdplus / SDS
What is the Network ID according to scanner?
bravo14
Polk County FL
I was locked in the Groveland site and showed nothing on the SysID. Just shows site 3. I was trying to see if clermont had a site it is not even online. Seems Groveland/Clermont for that area.
bravo14
Polk County FL
Earlier today I was able to get clermont site. I was on the way to Orlando and 856.400 popped up. Scanner Site 1 and dsdplus is 1.2
mtindor
OH/WV DB Admin
Are you using DSDPlus Fastlane for these sites, latest version? If you are, and if the database is correct that it is a MOT Capacity Max system, then DSDPlus isn't going to be showing 1.2, 2.3, etc. It's going to be giving regular site numbers. It's not going to be giving Areas (or what RR called Regions). MOT Cap Max will be TIIInonStd in the latest DSDPlus. Cap Max systems do not use Area IDs.
bravo14
Polk County FL
I do run the latest dsdplus. They are using TIIIStd (Auto) Site T1-1.2
mtindor
OH/WV DB Admin
If monitoring a clean signal on a strong site, BW 7.5, and it's _not_ saying MOT at the bottom, then you should submit to the DB for them to change the system from Capacity Max to Tier III Standard. The database says it is DMR Tier III Capacity Plus
trooper890
N/A
Which is it not. SECO Utilizes Tait equipment.
bravo14
Polk County FL
Last night bands were strong and I was able to get 2 sites. On RRDB 2 other sites 2.1 & 3.2 are listed.
Area 2 SIte 1 Clermont (Lake County on 27 at the sub station)
LSN / LCN / Freq
43/44 21 855.650
45/46 22 856.400 Control Channel
47/48 23 859.375
49/50 24 860.400
Area 3 SIte 1 Mount Dora (Lake County)
LSN / LCN / Freq
21/22 10 857.5875 Control Channel
23/24 11 859.0625
25/26 12 860.4125
Has anyone figure this one out on for this one not sure if online or offline. DeLand FCC Callsign WRFL554 (SUMTER ELECTRIC COOPERATIVE, INC.)
On 2.1 NL shows 2.3 I don't see 2.3 on any other sites.
