Swivel clip replacement
jblacker
Port Huron, Michigan
Hi all.
I have a Uniden BCD436HP and I bought a hard leather case from Scanner Masters to protect it. I use it at work and knew the plastic clip would fail. The issue I have is the belt clip receiver is bent from use and I can't find a replacement for just the belt clip. It is a swivel setup. The round clip on the case is about 1/2 inch. Any help on where I might be able to buy replacements would be great.
Thank you.
RandyKuff
Lorain, Ohio
You can always call Scanner Master and verify if the above clip will fit the case you bought from them....
