Sync Sdsharp from 2 locations?
dave3825
Suffolk County NY
I have sdsharp on my pc and on my laptop. I have a folder called sdr on both desktops with sdsharp, dsd+, vbcable and zalig inside.
Can I run that folder out of a google drive folder or a one drive folder? Trying to find a way to keep the two installs in sync, mainly the xml files, the config files and the .dll files.
Its a pain to have to do everything twice..
atouk
Jackson, NJ
All of the files to run SDR# reside in one folder making it completely transportable. Using a thumb drive, network share, or remote storage (as long as you have both read and write privileges), shouldn't give you any problems as long as only one instance of SDR# is running from that location at a time.
Voyager
That should work as long as the relative locations are the same for the program and any referenced programs (like DSD+). If they are in different directories, you would have to update the locations each time. (I.E. C:\DSD on one PC and C:\DV\DSD on the other)
