system fusion
rusty15
Flin Flon Manitoba Canada
I was wondering wheather the yeasu system fusion is able to be monitoreby any of the available scanners on the market at this time.
The AOR dv-1 receiver can.Also if you connect any scanner and use DSD+ Still fairly private for ham radio.....
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
Which -fX switch do you use to decode Fusion? I don't see it listed.
Code:
-fa	Auto-detect all protocols / frame types except dPMR
-fd	Decode D-STAR (no audio)
-fn	Decode NXDN4800 (Kenwood NEXEDGE and Icom IDAS)
-fN	Decode NXDN9600 (Kenwood NEXEDGE)
-fr	Decode DMR/MotoTRBO (TDMA inputs + both output slots)
-f1	Decode P25 Phase 1
-fx	Decode X2-TDMA
-fp	Decode ProVoice
-fm	Enable dMR decoding (no audio)
D
DaveNF2G
Guest
IIRC, System Fusion allows a repeater to pass both analog FM and DMR. The actual decoding would be of DMR, so it appears that -fr should do the trick.
