I switched my feed from DSD+ routed through VirtualCable and ScannerCast to SDRTrunk. While the setup was a breeze on my Windows 10 feed computer, when I tried to set it up on my main desktop with the hopes of getting rid of the extra power drainer, I ran in to an issue. When I try to configure the stream in the Playlist Editor I cannot set the System ID. I had no problem on the Win10 machine. I also noticed there doesn't appear to be a config file for the stream specifically to manually edit the config.
