Tailscale Configuration for SDR-Trunk and Rdio-Scanner
bg_nashville
I need help to configure Tailscale for use with SDR-Trunk and Rdio-Scanner. Here’s my setup:
Local Ubuntu machine running SDR-Trunk and Rdio-Scanner.
Remote Ubuntu machine located in another state running SDR-Trunk and streaming the files via the API Rdio-Scanner on my local machine.
I can setup Tailscale and Tailscale funnel and connect via a web browser or the iOS app to Rdio-Scanner.
I changed the Rdio-Scanner URL in SDR-Trunk to the funnel address that uses port 443.
Rdio-Scanner is not ingesting the streaming files on neither the local machine or the remote machine.
What am I missing in setting this up? I currently use a VPN with a static IP and port forwarding, but want to switch because Tailscale is free and it runs as a service. My paid VPN frequently disconnects.
bg_nashville
The solution to my problem was much simpler than I had expected. After entering the new url I needed to restart SDR-Trunk. Also, the change to port 443 was unnecessary.
