Tait TP9300 Wont Program
Dark_Hunter
New Zealand
I have 2 Tait TP9300s, 1 is VHF the other is UHF.
For some reason I can't get the UHF model into programming mode, but the VHF is will enter programming mode just fine.
Is there anything I can do to troubleshoot or find out what is wrong?
Z-master
Canterbury, New Zealand
Clean the pins under the accessory connector cover with IPA or something. Memory is failing me currently and I'm not at work, but I think it's the top two and bottom two pins are used for programming
Z-master
Well there's not too much to them.. if your cable works with one and not the other, then it must be a faulty accessory ribbon cable and probably needs to get serviced
