Talk Group ID: 4.0.41 Software
bkirk3434
I just got a new computer and downloaded the Unication G Series PPS software. Most of it looks the same as the previous version but looks totally different when I am attempting to add a new Talk Group. It is only giving me the option to name it, alert mode, alert tone, voice storage, relay control, and background color... I do not see any option to enter the TGID (DEC).
I don't see how I can make a new TG without adding the TGID but I am not seeing a clear way to do it. Can someone help with step by step directions to adding a new talk group from scratch?
There are two places it should be added the first is tab C1 look for the system you want to add the TG to and click on the TGID column for that system then ADD at the top, you also need to add it in tab E2 when the PPS is open follow the same procedures as in C1.
CommJunkie
FN20jf
I programmed everything in E2 and left C1 blank and have no problems.
K9KLC
Southwest, IL
You can do it that way, the advantage though of doing it C1 is you can use that system again for other pagers, PPS code plugs or whatnot , but it is not required.
I wish it would put it in C1 also when you do a RR import from the database, as it stands now it seems to me at least, it's only going to E2.
K9KLC
Southwest, IL
Works fine if you import from RR into C1, then reference public resources to build your profile.
I guess I'll have to try it again, I simply did the RR import into the profile. I'll have to see about getting it into C1. Thanks.
