More information needed as I can't look at the database for that county at the moment. What is the talk group for? Police,Fire, EMS etc. Is it possibly encrypted? Do you have the correct service type enabled? Are you close enough to receive it? Alot of variables to consider.Can't get Kosciusko County 43 (Indiana) talk group to scan. No issue with surround counties. I'm new to the sds200 scanner.
Fire and EMS. yes for service types and close to receive. There is not an E with the D but was wondering if it is encrypted. I know the county has encrypted law enforcement. I can get them on the Broadcastify app. When I us my zip code they don't scan but surrounding counties do. When I put them in a favorite with nothing else scanner said nothing to scan.More information needed as I can't look at the database for that county at the moment. What is the talk group for? Police,Fire, EMS etc. Is it possibly encrypted? Do you have the correct service type enabled? Are you close enough to receive it? Alot of variables to consider.
Are you using the main database along with your location and range? Or a Favorites list programmed for that county?Can't get Kosciusko County 43 (Indiana) talk group to scan. No issue with surround counties. I'm new to the sds200 scanner.
DEC | HEX | Mode | Alpha Tag | Description | Tag |
10866 | 2a72 | D | 43-EMA-OPS1 | County EMA Operations 1 | Emergency Ops |
10867 | 2a73 | D | 43-EMA-OPS2 | County EMA Operations 2 | Emergency Ops |
10875 | 2a7b | D | 43-KCF-DISP1 | County Fire Dispatch 1 | Fire Dispatch |
10876 | 2a7c | D | 43-KCF-DISP2 | County Fire Dispatch 2 | Fire Dispatch |
10870 | 2a76 | D | 43-FG1 | County Fireground 1 | Fire-Tac |
10871 | 2a77 | D | 43-FG2 | County Fireground 2 | Fire-Tac |
10872 | 2a78 | D | 43-FG3 | County Fireground 3 | Fire-Tac |
10868 | 2a74 | D | 43-EMS-DISP | County EMS Dispatch | EMS Dispatch |
10869 | 2a75 | D | 43-EMS-OPS | County EMS Operations | EMS-Tac |
10877 | 2a7d | D | 43-LAW-DISP1 | County Law Enforcement Dispatch 1 | Law Dispatch |
10878 | 2a7e | D | 43-LAW-DISP2 | County Law Enforcement Dispatch 2 | Law Dispatch |
10873 | 2a79 | D | 43-KCE-OPS3 | County Law Enforcement Operations 3 | Law Tac |
10874 | 2a7a | D | 43-KCE-OPS4 | County Law Enforcement Operations 4 | Law Tac |
10879 | 2a7f | D | 43-OPS1 | County Operations 1 | Multi-Tac |
10880 | 2a80 | D | 43-OPS2 | County Operations 2 | Multi-Tac |
Apparently they do, though the county's main RRDB page doesn't reference it at all....Ron10716, I believe "K" county has their own separate sytem,
Yep found and added that as an only favorite to rule out everything else. Can't get them to scan - have to manually knob to each one??Ron10716, I believe "K" county has their own separate sytem, not Safe-T. From the database select Indiana/County systems/K county govt. That's where I heard traffic last year when I was at Beaver Dam Lake
That's been corrected.Apparently they do, though the county's main RRDB page doesn't reference it at all.
So has something changed in the data base in the last couple days?That's been corrected.
The change was listing the county government trunked system on the county page.So has something changed in the data base in the last couple days?
