Nextel493
- Joined
- Apr 28, 2019
- Messages
- 29
Has anyone else noticed a really bad battery life on the Talkpod A36plus 8W version? I realize it has a much fancier display than the Baofeng UV-5R & UV-82HP, but I keep the back light timer at a minimum and have even tried the deep battery save mode. With little to no TX and very small amounts of RX, the 3200 mAh battery drops too quickly. I turned it on the other day and it read 7.8v and shut it off immediately after. Two days later with no use at all it reads 7.2v. My Baofengs, even the UV-82HP on high power, under the same conditions last a ridiculously long time. Is it the colorful display causing the problem, or is the A36plus 8W itself just a bad radio? Any ideas?
