Teamspeak Error Message
jimmnn
Colorado
Speaking of I have a teamspeak question for those knowledable in such.
I downloaded and installed the player on a new computer and can’t get the backgrounds sounds to cease such as new player has arrived, player has left etc.
Followed the instructions in the TS help area;
Turning Off The Female Computer Voice:
Are you tired of hearing "Tina TeamSpeak" barge into your speakers every three seconds, interrupting your favorite feed in the middle of a 2-Alarmer, just to tell you that another listener has joined or left the server...?!?! Thought so. Here's the solution:
1. On the TeamSpeak menu bar, click on "Settings"
2. From the drop down menu, choose "Options"
3. On the next screen, click on the "Sound Notifications" tab to bring it forward
4. Click to put a check in the "Disable all sounds" option box (in about the middle of this tab screen)
5. OK out to close the Settings dialog
But I keep getting a teamspeak error message “list index out of bounds -1” and will not allow me to cease the sound notifications?
Thanks in advance
Jim<
mlinthicum
Springfield, Ohio
Hi Jim,
Did you download from the TS website ( www.goteamspeak.com )? If so, make sure you downloaded the one that says " TeamSpeak 2 Client" not the one with the "(Updated Executable)" listed after it.
Otherwise, it's an uninstall and re-install.
jimmnn
Colorado
mlinthicum said:
Hi Jim,
Yes I believe I have downloaded and actually reinstalled the correct one twice, still the same error message.
Thanks Jim<
kc8qch
Cincinnati, Ohio
Thanks Jim<
What version of the Client are you running, Jim? I just tried it here on my client and i am not having problems at all. Go to help about. My version is 2.0.33.7.
scanjunkie
Montgomery County, PA
Don't know if it makes a difference or not, but are you registered with the server? It is under "Self>Register with Server."
You can tell when you log in...when your name appears on the list it will have a "U" next to it if you are not registered and a "R" if you are.
kc8qch
Cincinnati, Ohio
Doesn;t matter. I used both a registered user name and an unregistered to check (it's nice having your own server to not bother anyone LOL). My hunch is he has an older version of the client that had the bug and hasn't upgraded.
poltergeisty
Truth is a force of nature
Banned
RLG, Fly heading 053, intercept 315 DVV
Is it working now?
Are you using Vista?
I see you posted here with no response.
A haxx might be done by just going to the installation folder of Team speak and just delete the audio files (if there) for those voices. I don't know if that would work though and might have to modify a .ini file too.
