TeamSpeak Scanner Feeds
Tac-1
Linden, NJ
Teamspeak Server List
List of Active Teamspeak Servers
Teamspeak Servers
Server Name
Server IP Address
British Columbia Canada
ScanBC
142.103.195.219:8767
Fairfax County Virginia
Fairfax Scanner
71.163.54.134:8767
Incident Broadcast Network
IBN Live Scanner Broadcasts
incidentbroadcast.com:8768
Incident News Broadcast
feeds.incidentnewsbroadcast.com:8825
Jefferson County Ohio
OVSCAN Teamspeak
209.240.0.62:8767
Johnstown Pennsylvania
Johnstown PA Scanner Audio
207.255.12.221:8768
Laclede County Missouri OEM
LacledeOEM Radio Broadcast
65.41.196.169:8767
Messa County Colorado
Mesa County Scanner
72.174.20.210:8767
MILCOM
MILCOM
12.172.250.250:8767
Montgomery - BucksPennsylvania
Montgomery - Bucks PA Scanner
68.39.155.101:8767
New England Scanner
New England Scanner Feeds
nescannerfeeds.no-ip.org:8005
Scan West Massachusetts
Scan West Masss
66.189.5.227:8767
Scanner Buff Network
Scannerbuff On-Line
radio.scannerbuff.net:8767
Washington DC
DCFD SCANNER
66.55.146.51:8053
Tac-1
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
medic_35 said:
How do you listen to the feeds on team speak
Download Teamspeak at http://www.goteamspeak.com. If you're running Windows, download both the Teamspeak Client and the Teamspeak Client updated executable. Install the Teamspeak package, making note of where you installed it. Then copy the Teamspeak.exe updated executable that you previously downloaded over to the directory where you installed Teamspeak.
Then Execute Teamspeak. File / Connect. Then right-click on Servers, select Add Server.
File in the appropriate information including a name for that particular server, the Teamspeak host (such as ts.ovscan.com:8767), a nickname (anything you want - some characters aren't allowed), select Anonymous. Then click Connect.
Once you connect to the Teamspeak server, you'll want to click on Self, then Register with Server. Put in a username and password that you want to use register yourself on that particular Teamspeak server. use something you'll remember.
After you have successfully registered with the server, disconnect. Then go back to Connect, highlight the new server you created, and edit the properties where you put in your Nickname, etc. Change from Anonymous to Registered and then type in the Login Name and User Password (the same ones you used when doing Self/Register with Server).
Then Save that info and connect again. When you log into the Teamspeak server now, you'll see an (R) next to your name indicating that you are registered. The reason why you should register is because most scanner audio feed sites require one to register before they can join the various channels and listen.
Mike
RedPenguin
I know this an old thread but, I have a question....
I know this is an old post, but I a question about one of the servers listed that happens to be in my area.
Does anyone know who owns 207.255.12.221:8768?
I just want to ask them a few questions about what frequencies they have programmed in.
Livewire3286
Montesano, Wa
Hmm didn't know that one was up. looks like its just a guy doing it on his own. Ive never seen anything posted on or about his feed.
