Teardown instructions for hmn1038a desk mic
thesavo
Schenectady, NY
Does anyone know how the PCB and rocker assembly come out to repair the leaf switches in an hmn1038a desk mic?
I got the base plate, back and front covers off. However I am struggling to free the pcb and rocker button assembly.
Can anyone provide some insight? I don't want to break it further.
Thanks.
ramal121
Lots and lots of watts
Calif Whine Country
The pin the rockers pivot on, pull the clip off and collapse the pin inward. Pull the whole banana downward.
thesavo
Schenectady, NY
Oh.
Pull this clip and the pin retracts. That is a neat design.
thesavo
Schenectady, NY
Wow. That worked well. Thanks.
I took this apart to see what's wrong with the PTT switch.
Pressing the switch on the top end, keys the mic without issue. However, it seems to have lost the "throw" distance and the user has to press hard or quickly. Both I feel will damage it further. Is there any corrective action that can be made?
The monitor switch, doesn't have this issue . Presumably because it is used far less frequently.
There doesn't seem to be any worn away material.
dickie757
Wired
Out of range
How does it respond when you press in at the top/vertical, above the tx spark? That is my usual way of PTT. When that way is used, the bottom/horizontal part will lift up.
thesavo
Schenectady, NY
Pressing the side button keys every time, especially with a continuity test. In that manner the horizon potion of the button lifts up according.
Pressing it down is intermittent. the top side leads out pulling the leaf switch, just not enough it seams.
There is no issue with the monitor button.
