Tecsun PL-660 Battery Life: erratic or just my batteries?
pinballwiz86
Missouri
Use headphones. I've had the same set in there for months now. About 30 minutes of use couple times a week.
Also, turn off the back light by hitting "5" when the power is off.
Should help extend the battery life. Oh and the supplied rechargeables aren't very long lasting to begin with..I'm using Rayovac cheapie alkaline batteries.
gregtheham
Toronto Ontario
High Battery Drain Follow-up
Just a follow up on what I am finding with FRESH alkaline batteries. After burning through 3 sets of different makes, (Raocvac, Energizer, No-name) I am quite shocked at how fast the batteries are draining - even when the radio is off!
I dont know if the LCD display is the problem- dont know why it should be- but after a new set, the radio is almost dead after four days of power off, and then about 5- 10 minutes of on time. Volume kept is low to reduce current use. Backlight kept off. I am quite dissapointed.
Could this be a defect? Timer is off, so its not turning on at some unnoticed time.
I will try the reset button, but cant imagine it making a difference.
Looks like I will have to be taking the batteries out when not in use- not something I should have to do.
As noted before, using the radio from the install of a fesh set seems to also eat up batteries in the matter of 3- 4 hours.
Full charged batteries are required as performance really drops as battery charge drops below half on the bar display.
Back for an exchange? Typical for this radio? I have never seen this much current use in any of my previous portables...any technical advice or ideas ?
Greg
