Tecsun PL-880 issues
MikeinDestin
Destin, FL
I've had mine for quite some time. Occasionally when powering on, it might show "On" with no audio, or a frequency with no audio. None of the pots are responsive, or the power switch. Last time I removed the battery, and after replacing it everything worked ok. Didn't lose any memories. When I first got it the display light stopped working, but after a reset that cured it. I read in some forum that there's a rechargeable button battery on the pcb that needs to be charged often, as it supposedly powers the mixer and other circuits. That seems like a lousy design, but whatever. Has anyone else had similar issues? Thanks for any responses.
Boombox
Does it have a rechargeable battery? Is it very old? An old rechargeable battery can glitch. That happened to one of my radios, which has an old BL-5C. That battery still will operate the radio, but I don't let it get below one or two bars. The last time I did, it caused the radio to wig. Lose memories, forget which MW kHz step I had it on, etc. Charging the battery to full, and then resetting the radio fixed the glitching. Luckily, I got the radio's SW memories back.
Maybe get a new battery, and just keep the old one as a backup.
MikeinDestin
Destin, FL
I never let the batteries get too low, I charge them at around 3.6v, and they have never been below that. Doing a reset does always work. Like I mentioned before, someone claims this model has a rechargeable button battery on the pcb, which can act up if not used enough. Supposedly the button cell operates some of the circuits, not just memory. It could be either battery.
Rq17954z
Waterbury CT
Mine has some issues, will move off the set frequency and have to re adjust. Display will come on when powered off sometimes. Sometimes becomes unresponsive have to remove the battery and reinstall. Bought off eBay was sold as used but was brand new just didn't get a warranty with it! So think that's why it was such a good price. Other than that it's not bad
MikeinDestin
Destin, FL
I like it except the AM performance is mediocre. It's nice having a radio with digital frequency readout, since all my older radios don't have that, and sometimes you are looking for a particular frequency.
Boombox
Another potential issue I encountered with my Tecsun PL-398, which uses 3 AA's. When I moved the radio one day, just holding it, it turned off after giving me a 'low battery' warning. The batteries were new. It happened twice.
It was the battery moving around inside the case, just enough to cut out the power for a few milliseconds or so. I could tell that the battery was moving slightly, because when I opened the compartment I could wiggle the AA slightly. So I tried a shim.
I cut a shim out of some plastic (from a plastic bottle which had flat sides) and shoved the shim against the battery in the battery compartment. The compartment cover still closes OK. The shim keeps the battery from moving at all. I haven't had any problems like that with my Tecsun since.
It might be your rechargeable is moving around in the compartment just enough to cut out..... Or not.... It's still worth trying, though, if you still have this issue. A plastic shim would be cheap enough to make, and it would either stop the problem or at least help you zero in on the cause of the problem if the shim doesn't help at all.
I've used shims in other radios where batteries moved around. In my Sangean PR-D5 battery movement caused crackles in reception when I moved the radio. The shim stopped that. My DX-375 would need the power button pressed a couple times to turn on when the batteries got a bit low. The shim solved that, too.
MikeinDestin
Destin, FL
Thanks very much for your reply. The issue hasn't returned, so hopefully it's alright. I will remember that though. The battery appears to fit tightly in the compartment.
Boombox
Glad to be of at least some help. Like I said, sometimes these modern radios don't like power cutting even for milliseconds. A shim can help, and it can't hurt.....
Enjoy your radio, man. I enjoy using my Tecsun.
MikeinDestin
Destin, FL
I've had another problem with the '880 for awhile now. It's more noticeable on FM than any other mode. While listening to a station, you hear a second audio artifact that sounds like ssb, along with the main carrier. Sort of like Donald Duck added to the main audio.
Probably nothing I can do about it. At first I thought maybe it was the speaker, but I really dunno.
Boombox
Is it the same on headphones? That would narrow it down to the speaker, or something else in the radio.
MikeinDestin
Destin, FL
I measured the current drain. Since there was much discussion about the power hungry Qodosen, I thought I'd try my PL-880.
On FM got 103mA. AM/SW 130mA. It's very difficult to do, since it almost requires 3 hands. The probes won't stay put, making it virtually impossible to get a steady reading. Then holding the battery and pushing the power button.
MikeinDestin
Destin, FL
I'm still getting the audio issue, but just noticed something. It's only doing it on one station. (Sounds like SSB on FM along with FM). I listened to the station on another radio and couldn't hear the issue. Tuned across the band and couldn't duplicate the problem with any other station. It's only doing it on one station on FM, no other bands or modes. Of course that makes it tougher to diagnose, but also a relief the radio is ok.
