Telemetry with PD78x
ottosykora
Basel, Switzerland
I have here some PD78xG and I want to make use of the telemetry function as it is mentioned in the system planer manual.
In CPS, conventional, general setting there is the setting for it. The basic setting is under general settings, accessoties.
OK, under accessories, active level is high.
I managed so far to set in the sending radio a telemetry command, let say send active voltage, transmit it to other radio to the VIO1 apparently.
However at the target radio, the pin#11 just has some pulses of some 0.5V and some 20ms wide. About 4 of them.
Thats it.
No idea how to make it work.
Output measured between #11 and #6(GND) with some special adapter made from some audio connector rest.
Is there someone who made this telemetry working?
Does there exist some appnote for that?
thanks
otto
ottosykora
Basel, Switzerland
Many thanks.
Meanwhile I have produced some aid to contact the pin11 and 6.
After some tests, I found out that it is possible to switch the output on and off and send a pulse.
However the query or report when status chnages does definitely not work with fw 9. The radios do communicate indeed, however there is no display of the status.
I will try more, but I think I am a very rare species, nobody probably does it , therefore no industry made connector for telemetry exists and therefore hytera does not spent time on it.
I will anyway try to write some report on this and pass it to hytera one day.
Or if we find someone who has some practice in it and tells me where are some changes in the fw on this part.
ottosykora
Basel, Switzerland
You can take the app note from #2 and there all is described.
Telemetry with Hytera radios means that you can for example switch something on and off or read the status of a device remotely using two radios programmed to do so.
With PD78x, one task is to wire the pin11 of the accessory connector. This is the input/output on the portable radios.
On mobile radios, I/O pins are on the accessory connector at the rear of the radio.
