Tempermental G5
19sargeusmc56
Any tips on coaxing a G5 into connecting to pc? USB mounts fine, just doesn't connect.
w2lie
New York DB Admin
Long Island, NY
You may need to reinstall the drivers. They are available on the Unication download page under the PPS download link.
K9KLC
Southwest, IL
Mistakes I've made: #1 make sure the pager is actually on...I've done this numerous times. #2, Make sure you're using the Unication cable or at least a bonified data cable, I honestly use other cables at times but sometimes I grab the wrong one and it doesn't seem to handle data very well.
Other than that as @w2lie said, grab the drivers off Unication's site and start over and try again.
CollinsURG
North Carolina
I have had this happen several times due to reprogramming when I first got mine until I got it setup how I like it. Still happens sometimes.
I figured out a better solution than removing the battery.
In "Function Settings", go to "13. Factory settings". "Reset GX to Factory Settings. Then connect and reprogram. Has worked every time so far.
Replacing driver files never worked for me. It is apparently something in the G5 that needs to be corrected by Unication. Maybe firmware?
19sargeusmc56
Cool.
Another G5 question? Can recorded messages be exported from this thing......anyone know?
