libtoolize: putting auxiliary files in `.'.
libtoolize: copying file `./ltmain.sh'
libtoolize: putting macros in AC_CONFIG_MACRO_DIR, `m4'.
libtoolize: copying file `m4/libtool.m4'
libtoolize: copying file `m4/ltoptions.m4'
libtoolize: copying file `m4/ltsugar.m4'
libtoolize: copying file `m4/ltversion.m4'
libtoolize: copying file `m4/lt~obsolete.m4'
configure.ac:14: installing './compile'
configure.ac:16: installing './config.guess'
configure.ac:16: installing './config.sub'
configure.ac:5: installing './install-sh'
configure.ac:5: installing './missing'
src/Makefile.am: installing './depcomp'
src/gsm/Makefile.am:14: warning: source file 'milenage/aes-encblock.c' is in a subdirectory,
src/gsm/Makefile.am:14: but option 'subdir-objects' is disabled
automake: warning: possible forward-incompatibility.
automake: At least a source file is in a subdirectory, but the 'subdir-objects'
automake: automake option hasn't been enabled. For now, the corresponding output
automake: object file(s) will be placed in the top-level directory. However,
automake: this behaviour will change in future Automake versions: they will
automake: unconditionally cause object files to be placed in the same subdirectory
automake: of the corresponding sources.
automake: You are advised to start using 'subdir-objects' option throughout your
automake: project, to avoid future incompatibilities.
src/gsm/Makefile.am:14: warning: source file 'milenage/aes-internal.c' is in a subdirectory,
src/gsm/Makefile.am:14: warning: source file 'milenage/aes-internal-enc.c' is in a subdirectory,
src/gsm/Makefile.am:14: warning: source file 'milenage/milenage.c' is in a subdirectory,
tests/Makefile.am:19: warning: source file 'a5/a5_test.c' is in a subdirectory,
tests/Makefile.am:19: but option 'subdir-objects' is disabled
tests/Makefile.am:25: warning: source file 'auth/milenage_test.c' is in a subdirectory,
tests/Makefile.am:25: but option 'subdir-objects' is disabled
tests/Makefile.am:28: warning: source file 'bits/bitrev_test.c' is in a subdirectory,
tests/Makefile.am:28: but option 'subdir-objects' is disabled
tests/Makefile.am:22: warning: source file 'comp128/comp128_test.c' is in a subdirectory,
tests/Makefile.am:22: but option 'subdir-objects' is disabled
tests/Makefile.am:31: warning: source file 'conv/conv_test.c' is in a subdirectory,
tests/Makefile.am:31: but option 'subdir-objects' is disabled
tests/Makefile.am:67: warning: source file 'fr/fr_test.c' is in a subdirectory,
tests/Makefile.am:67: but option 'subdir-objects' is disabled
tests/Makefile.am:58: warning: source file 'gb/bssgp_fc_test.c' is in a subdirectory,
tests/Makefile.am:58: but option 'subdir-objects' is disabled
tests/Makefile.am:61: warning: source file 'gb/gprs_ns_test.c' is in a subdirectory,
tests/Makefile.am:61: but option 'subdir-objects' is disabled
tests/Makefile.am:37: warning: source file 'gsm0408/gsm0408_test.c' is in a subdirectory,
tests/Makefile.am:37: but option 'subdir-objects' is disabled
tests/Makefile.am:34: warning: source file 'gsm0808/gsm0808_test.c' is in a subdirectory,
tests/Makefile.am:34: but option 'subdir-objects' is disabled
tests/Makefile.am:40: warning: source file 'lapd/lapd_test.c' is in a subdirectory,
tests/Makefile.am:40: but option 'subdir-objects' is disabled
tests/Makefile.am:64: warning: source file 'logging/logging_test.c' is in a subdirectory,
tests/Makefile.am:64: but option 'subdir-objects' is disabled
tests/Makefile.am:70: warning: source file 'logging/logging_test.c' is in a subdirectory,
tests/Makefile.am:70: but option 'subdir-objects' is disabled
tests/Makefile.am:43: warning: source file 'msgfile/msgfile_test.c' is in a subdirectory,
tests/Makefile.am:43: but option 'subdir-objects' is disabled
tests/Makefile.am:49: warning: source file 'sms/sms_test.c' is in a subdirectory,
tests/Makefile.am:49: but option 'subdir-objects' is disabled
tests/Makefile.am:46: warning: source file 'smscb/smscb_test.c' is in a subdirectory,
tests/Makefile.am:46: but option 'subdir-objects' is disabled
tests/Makefile.am:73: warning: source file 'strrb/strrb_test.c' is in a subdirectory,
tests/Makefile.am:73: but option 'subdir-objects' is disabled
tests/Makefile.am:52: warning: source file 'timer/timer_test.c' is in a subdirectory,
tests/Makefile.am:52: but option 'subdir-objects' is disabled
tests/Makefile.am:55: warning: source file 'ussd/ussd_test.c' is in a subdirectory,
tests/Makefile.am:55: but option 'subdir-objects' is disabled
tests/Makefile.am:16: warning: source file 'utils/utils_test.c' is in a subdirectory,
tests/Makefile.am:16: but option 'subdir-objects' is disabled
tests/Makefile.am:76: warning: source file 'vty/vty_test.c' is in a subdirectory,
tests/Makefile.am:76: but option 'subdir-objects' is disabled
