Scanning with rtl stick (even "over the network" with rtl_tcp) is working much better than with HackRF.I've tried to play a little with scanning. Because I don't have a "spare rtl stick" I've used HackRF One.
https://github.com/sq5bpf/telive/raw/master/telive_doc.pdf
How to report problems with telive? On forum in thread or create issue on github?also please report any errors in the new telive version.
It's also working with Ubuntu 16.04 but you have to change "ubuntu 15" to "ubuntu 16"i've added a minor tweak to the install_telive.sh script to allow installation under raspbian 8
Actually I've noticed strange behavior on Debian decoding with "remote RTL stick" (rtl_tcp) is NOT working (signal lost/signal found on telive, out of buffer space on rtl side). The same setup on Ubuntu 16.04 is working fine.
It's only "distro depended", the same hardware and network setup, only difference Ubuntu 16.04 vs Debianyou probably need to tweak some buffer sizes.
also try to see if this isn't a network issue, especially if wifi is involved.
the issues are either with gnuradio (different version, so maybe different buffer sizes etc) or with the network stack. for example there might be a different wifi driver causing more packet drops, and these will cause tcp retransmissions etc (use a sniffer to check).
I agree that's probably gnuradio issue. For sure not WiFi (using LAN connection) ;-)
I can confirm that number displayed below the user(s) ISSI in the usage identifier when on a clear network is the GSSI. I think I remember reading earlier in the thread people weren't sure which was the group ID.
