Tetra decoding
sq5bpf
After the last update I get a lot of messages like :
DRELEASEDEC SSI:xxxxxxx CID:xxxxxxx NID:xx [Call rejected due to SS-AS] RX:1
Whats does this mean ?
this is the D-RELEASE message parsed. the "Call rejected due to SS-AS" is a verbose representation of NI:16
sq5bpf
I get a lot of SDS Messages, should these not be decoding ?, have I set my telive up wrong womewhere ?
20150314 20:26:58 FUNC:SDS [01001111100010011110101010001000011101110011111110101100100101]
20150314 20:26:58 FUNC:SDSDEC [CPTI:2 CalledSSI:5443919 CallingSSI:2599457 CallingEXT:14483122 UserData2: 0x74 0x30 0x44 0x69] RX:2
20150314 20:27:22 FUNC:SDS [01001111001000110011010101001011000001011001101100011010101011]
they are decoding correctly. user data 2 is just 4 bytes. in your case they are 0x74 0x30 0x44 0x69.
if you find out what application uses this data, then you might be able to make some sense out of this data.
there is also user data 1 SDS, which can send 2 bytes, and user data 3 SDS which can send 8 bytes, and user data 4 SDS-es which can have arbitrary length and are used for sending text messages, various location protocols, remote control and many else.
tmanuk
I get this too.. What is NI:16 ?
Ok, Kind of figured it out from the etsi documentation:
Area Selection (AS) allows an authorized user to define areas for selection and a served user to choose, on a call by call
basis, a selected area to be used for establishing a call. This SS-AS shall not restrict normal roaming (e.g. the call
re-establishment facility). SS-AS may also be used to restrict areas for other services.
yt1pro
Hi!
I have problem with installing GNU Radio:
When i try to run install script "wget http://www.sbrac.org/files/build-gnuradio && chmod a+x ./build-gnuradio && ./build-gnuradio -o" , I'm getting this message:
Failed to find just-installed command 'git' after pre-requisite installation.
This very likely indicates that the pre-requisite installation failed
to install one or more critical pre-requisites for Gnu Radio/UHD
This script was working for me a month ago, but now is not working.
Does anyone know what is the problem?
sq5bpf
it's hard to say, because we can't see everything in our crystal ball.
please provide basic info, show some debugging information etc
did you search on the internet if other users of this script had similar problems?
without these answers you're just wasting everyone's time here
grosminet
again
Again don't bother with Sbrac script !!
Install Kali linux any version . You will have a stable debian with root anywhere and then install:
apt-get install kali-linux-sdr
which is the 3.6.X gnuradio software . It is installed in 2 minutes and the you follow the telive.pdf
easy
French team
tmanuk
autoreconf -i
no ,just follow the telive procedure
I thought I would give this a go, I have installed Kali, but when I work through the docs and type autoreconf -i I get the following:
root@root:~/libosmocore-sq5bpf# autoreconf -i
src/Makefile.am:7: Libtool library used but `LIBTOOL' is undefined
src/Makefile.am:7: The usual way to define `LIBTOOL' is to add `LT_INIT'
src/Makefile.am:7: to `configure.ac' and run `aclocal' and `autoconf' again.
src/Makefile.am:7: If `LT_INIT' is in `configure.ac', make sure
src/Makefile.am:7: its definition is in aclocal's search path.
src/codec/Makefile.am:7: Libtool library used but `LIBTOOL' is undefined
src/codec/Makefile.am:7: The usual way to define `LIBTOOL' is to add `LT_INIT'
src/codec/Makefile.am:7: to `configure.ac' and run `aclocal' and `autoconf' again.
src/codec/Makefile.am:7: If `LT_INIT' is in `configure.ac', make sure
src/codec/Makefile.am:7: its definition is in aclocal's search path.
src/gb/Makefile.am:11: Libtool library used but `LIBTOOL' is undefined
src/gb/Makefile.am:11: The usual way to define `LIBTOOL' is to add `LT_INIT'
src/gb/Makefile.am:11: to `configure.ac' and run `aclocal' and `autoconf' again.
src/gb/Makefile.am:11: If `LT_INIT' is in `configure.ac', make sure
src/gb/Makefile.am:11: its definition is in aclocal's search path.
src/gsm/Makefile.am:12: Libtool library used but `LIBTOOL' is undefined
src/gsm/Makefile.am:12: The usual way to define `LIBTOOL' is to add `LT_INIT'
src/gsm/Makefile.am:12: to `configure.ac' and run `aclocal' and `autoconf' again.
src/gsm/Makefile.am:12: If `LT_INIT' is in `configure.ac', make sure
src/gsm/Makefile.am:12: its definition is in aclocal's search path.
src/vty/Makefile.am:8: Libtool library used but `LIBTOOL' is undefined
src/vty/Makefile.am:8: The usual way to define `LIBTOOL' is to add `LT_INIT'
src/vty/Makefile.am:8: to `configure.ac' and run `aclocal' and `autoconf' again.
src/vty/Makefile.am:8: If `LT_INIT' is in `configure.ac', make sure
src/vty/Makefile.am:8: its definition is in aclocal's search path.
autoreconf: automake failed with exit status: 1
Any ideas ?
EDIT : Got sorted, Installed the following
sudo apt-get update
sudo apt-get install libtool
ET-NL
Netherlands, Europe
I want to rebuild my sdr machine, swichting from VM to physical machine. It is a Cor2duo 3G proc with 6GB RAM. Do you have a tip for a Linux distribution? In my VM i'm using Ubuntu 32 bit. For this machine I want to use 64bits.
sq5bpf
basically any linux distrubution that you're familiar with.
i recommend debian 7, but the recomendation to use kali also seems like a good one (but i haven't tried it).
you can also try stuff like ubuntu or mint, people have reported that they have slightly lower performance (probably because of all the crap they install by default), but they might be easier to use for some people.
grosminet
Any ideas ?
sudo apt-get update
Maybe you have to change source.lst in etc/apt in order to have more repositories
after :
apt-get install autoconf
apt-get install gcc-multilib for 64 os
apt-get install alsa-utils
and then follow the telive.doc
sq5bpf
i've broken the osmo-tetra-sq5bpf repository. i still don't understand well how git works, and i merged a whole pull request, instead of merging only part of it.
i will post a message when it is fixed
grahampaull
Sharpening my pitchfork! :)
sq5bpf
ok, should be fixed now
i've added a patch from Antonio Eugenio Burriel to make the codec work correctly when compiled for a 64-bit enviroment. so for new 64-bit installations you don't have to install a 32-bit build environment to build the codecs.
Antonio's other patches to make it work under gnuradio 3.7 are in the test-3.7 branch (currently untested).
ET-NL
Netherlands, Europe
Goodmorning,
I tring to install my new tetra machine.
Downloaded a 64bits Debian 7.8 installer and installed my machine with it. My problem starts when I run the build-gnuradio script. I changed the script following te Telive documentation to add support for 7.8. The script starts checking dependencies, fetches gnuradio and uhd. It the starts with "Building UHD..." and exits with the error "UHD build apparently failed".
The user i'm using is sudo and root member, tried to run the script as root but this doesn't work sudo ./build-gnuradio is not allowed either.
Thanks,
Elmar
