that won't work my estimate if same network around 4 to 6 before they start mixing up.
That's the reason why i run a separate instance of telive for each channel now days.
and this is for all channels from the same LA?
if so, you can consider this a known bug. currently all calls are tracked by the usage identifier, next version is planned to have different call tracking (the call id will be the key), and this should fix this problem
unfortunately i can test this software on networks with more than 4 frequencies per LA. for networks with less channels the current scheme works well
