KVL3000
So The TNG was just activated to counter the protests accross the state. Just a heads up to keep an eye out on those freq's
That is a conventional repeater, not trunked.Yes - just loaded those in. In fact saw one updated in the last 24 hours it is 150.7375 - Marked as P25 - put that in my BCD996P2 but cannot get anything on it...thinking I have to plug in more info like I do for normal trunk setups...like System ID and WACN #.
Does anyone know if I have to add that is that P25 part of a system - say GATTRS in Austin area?
What agency does that belong to? trying to find on my 436136.2750 AM Discussing IR. Busy as heck (Field & Patterson area, discussing same group??) I had it in FM first and tagged as GOV Multi-Agency.
EDIT: Figured it out
There was some discussion about this list many years ago.
We have heard 136.275 MHz used by DEA in the Houston area.136.2750 AM Discussing IR. Busy as heck (Field & Patterson area, discussing same group??) I had it in FM first and tagged as GOV Multi-Agency. OK, they are calling this "COM 2" (Whoever they are) OK last edit, I have this as "Common Federal" Probably Air Assets over Dallas discussing their camera systems.
I happened to catch 142.400 MHz PL 127.3 used at a COVID-19 testing site near me yeterday.
Same in N TX. It's supposed to belong to DEA.We have heard 136.275 MHz used by DEA in the Houston area.
It was (except for the last two lines that were added recently) allegedly read from a radio during a training exercise in S TX.
Some of the frequencies are likely bogus or incident-specific.
Two of the frequencies are in the 2m amateur band.
Four of the frequencies have regular AM aircraft usage in N TX.
I would suggest searching 138-144, 148-150.8 and 380-400 in 12.5 kHz steps and look for P25 or NFM signals.
During Super Bowls and other events they used field deployable repeaters in the 380-400 MHz band.
I had it as NFM when I heard it the first time but it sounded way off frequency only after I changed it to AM did it come in clear. It was discussion on how to set the IR lock on a camera system they were trying to watch a group at Patterson & Field downtown Dallas. I'm way too far out to search your suggestions, some of these local guys would have better luck. I had to raise a 9 element yagi in snake infested tall grass at midnight just to hear regular DPD channels. By the way, DPD just issued a 7 to 7 curfew effective tonight.There was some discussion about this list many years ago.
Looks like TX DPS was using for A2A between SPECTRE243 and Air101136.275 is DOJ (FBI and DEA usage; they each have their own respective air surveillance units)
