TG Scan issues on G4
hjvan
So I have a weird situation where one of my knob positions set up for TG Scan is receiving random TG IDs that aren't included in the TG ID's programmed. It's almost like it's acting like TG Scan plus TG monitor mode on the same channel.
Any ideas on why i'm receiving TG ID's showing up that aren't programmed for this channel????
Thanks in advance!
Heath
krokus
Southeastern Michigan
Thanks in advance!
Heath
Do you have wildcard search enabled?
Sent using Tapatalk
jzarick
Check your tgids. I had the same problem. I had it set up for scan and not monitor which is what you want for the tgids you only want to hear and I still was hearing everything. The next day I went and checked my tgids I put in and I must have typed it wrong or something but I had a wildcard number in there instead I forgot the number but the hex was all F's. I put the correct tgid in and everything is good.
Sent from my Pixel XL using Tapatalk
hjvan
sure enough. Went back and somehow a wildcard tgid was on there. Not sure how. Appreciate it all.
troymail
Silent Key
Which system? I've seen some systems listed in the past as having some type of 'All Call' talkgroup with a TGID of 65535.... but given the PPS, you'd probably know if you entered it.
