- Joined
- Jul 5, 2011
- Messages
- 556
- Reaction score
- 235
I am using it sitting next to a legit set of subscriber units, so i am dragging the talk groups with me whereever I go. Potentially they are all landing onto different sites (there really aren't many to choose from (Roane/Loudon/West Knox TN), and I generally move enough they all have to hand off fairly frequently and consistently). I have a RFSS button on the mobile, but honestly, at this point not interested in testing much more.Are you trying to monitor one site, or multiple? Just because it's on site "A" doesn't mean the talkgroups you have in you list are carried on site "A." Some may be on site "B" and the others are "A." This is not a fault of the Pager, but this is how the system was set-up. Not all talkgroups are carried on all sites, as that would use up a lot of resources.
I put it on a dedicated mobile antenna. This slightly improved the dead spots, but it still is much worse than the mobile and portable. I still am not sure how I am misprogramming it, sometimes it will sort of work, and other times, without resetting or power cycling... it will not open up on the same talk groups I am scanning on the mobile. There does not seem to be any rhyme or reason to it.
The new stubby antenna still does not pick up as well as the legit portable. It is hypersensitive to location and orientation in the vehicle, the portable... way less so.
I would not trust it as a pager or a substitute for a receive only portable unit where I am with the probably malformed program I have in it.
I have not tried to load keys into it to see how it decodes. I wanted to reduce variables.
I no longer have any handheld scanners handy to reference against, and I kind of believe using a legit subscriber unit is kind of unfair to the thing.
Also, there are talkgroups I wish to listen to, that are not in any of my legit radios, so, even if this thing was hitting on all cylinders, it still won't drag a group if it is not on the tower or the site is a... home (I forget the term for if the site just carries the TG) site (for like statewide or pursuit or other districts that would be, I suspect, geofenced to conserve site resources).
I do think this particular unit would be an excellent home / stationary scanner. Unfortunately, I am not home 24/7 like I was the last few years.
I don't know how to solve my particular problem as the grownups aren't really interested in the problem, but I don't think this is the answer. Suppose I will look at a BK or Harris next.
Thought I would follow up for others in the future (reading old stuff has been a huge help to me).
