The NEXT dumb question....Please select a profile
Johnsville, Frederick County, Md
OK, I think I was successful in putting one system in! Knob position one, done! (I'll know tonite if I did it right...). I'm trying to put another system on to Knob slot 2, and it keeps giving me the "Please select a profile', and I've tried everything for the past 2 hours, without success. I even totally shut down the system....and now I can't even find the radio reference data. I don't see a radio button, or anything else.
Any additional assistance much appreciated. I would happily pay folding money to someone who would write a simple programming guide for this thing!
bob550
Albany County, NY
We could provide more help if you tell us the model of G-series you have, the firmware version, and the version of PPS you are using. If you are attempting to import from RadioReference, you should import only after opening the profile you have created. I recreated the "Please Select a Profile" message when attempting to import a system before opening my existing profile for editing. I was able to back out, open my profile, and successfully import the system from RR. You should find considerable programming help for the latest PPS version on this forum.
4909
Thanks, everyone for ALL your assistance. Well, when I got home the unication wouldn't pick up my home county (the out of range) and with all the other issues this thing has given me, I've decided to sell it. Posted on fleabay today!
tunnelmot
Conroe, TX
Damn. That was over quick.
The Unications were originally intended as authorized system receivers. They require a bit more programming than a consumer scanner, but slightly less than an authorized system PTT subscriber. The ultimate balance if you ask me. Nothing less than flawless rx on my local systems...
Right of the cuff by what little you've described, myself or several others on the forum probably could have assisted fairly easily after looking over your prog file and system...but whatever.:rolleyes:
bob550
Albany County, NY
Patience is a requirement of programming the G-series, although it's far easier now with the RR import feature. In any event, it's not a process you can sleepwalk through.
eorange
♦RF Enabled Member♦
Cleveland, OH
C'mon, it's not that hard. Define a trunking system with the usual parameters you should already know about, associate with TGIDs, set up zones, done.
Professional radios are not for appliance operators.
