The Shack... 2022
wa8pyr
Lead Database Admin
Ohio
Well, it's taken awhile but I finally got my shack operational after moving it to a new room.
Shack was in the small bedroom at the top of the stairs and the mid-size bedroom was the guest room. The former was just too small for the shack (although it served me well for many years), so I decided to make the small bedroom the guest room and the mid-size bedroom into my shack.
Took the better part of a year to get everything swapped; I've got back problems, and getting the guest room functional was higher priority so when my Mom came to visit she would have a place to sleep. Once that got done I was able to really start on the new shack. And here it is...
On the main desk, there's an RSPduo and an Anytone AT-D578UVIII DMR radio on the top shelf (under the Apple Cinema Display).
On the lower shelf, there's an Icom IC-7300 and IC-R8600, with a Pro-2004 scanner next to the 8600.
Above it mounted on the wall is a 40" TV which can be used as a TV or as another monitor for the Mac Mini on the radio desk. Main computer on the other desk is an M1 Mac Mini with two 27" Dell monitors.
The scanner rack has a Zetron Model 27 receiver monitor panel at the top. The top row is an SDS200 and Pro-2035; below that, two Radio Shack Pro-197s, and below those a Uniden BCD996XT and BCD996T. Finally at the bottom, two Motorola XTL2500s, one VHF and one UHF.
Some of the scanners have separate antennas; the others are connected to a Monitenna clone through an Electroline distribution amp/splitter.
The panel below the Uniden scanners contains (left to right): DB9 connector for the OS535 in the Pro-2035; RJ45 connector to the network router (so I can connect a laptop if needed); RCA connector to the discriminator jack on the Pro-2035; BNC connector to the Electroline splitter.
Nice to finally have everything more or less situated so I can use it. Now, to reduce the pile of boxes in the back of the room and get the bits and pieces organized....
N9JIG
Sheriff
Moderator
Far NW Valley
Looks great! I like how you remote the connections on the rack, makes it really easy to use them when needed!
wa8pyr
Lead Database Admin
Ohio
Thank you! The new shack looks great BTW. And it's great to see other Mac uses in the radio hobby ;). Maybe one day we'll have some software lol..
Thanks!
Actually, RT Systems has started addressing that; several of their programs are available in both Mac and Win now, and more coming.
There's also a program called WFView for the Icom "base" radios, works pretty well.
IC-R20
LoBand Nation
Can I come to your house and play SIGINT post? Lol
KC1UA
This ain't gettin us noplace, we'll have to blast!
Outstanding. I need to do some research on that Zetron. I've been looking for a more effective way of sharing audio between radios. Nice to see another racked shack!
Omega-TI
Ω
Washington State
I would dearly love to see a photo of your shack with the main lights turned off and only the equipments illumination. I bet it would look like something out of a science fiction movie.
N1TPH
MA
Nice to finally have everything more or less situated so I can use it. Now, to reduce the pile of boxes in the back of the room and get the bitsLo
Looking good Tom! I'm just about to implement the ZM27 into my enclosure. Is wiring from scanner for speaker stereo or mono, and is shielded cable required? Thanks.
wa8pyr
Lead Database Admin
Ohio
Mono, two speakers with four inputs per speaker. Doesn't have to be shielded cable, although if you prefer to go that route it wouldn't hurt anything. I used two lengths of CAT5e (one length for each side of the panel, and one pair per cable for each radio/speaker connection) and it works fine.
N1TPH
MA
Thanks... with these and other details you provided, was successful installing the ZM27, getting rid of the old speaker setup. Next, I am trying to eliminate the PS and rackmount to reduce some more wait, and then the installation of two SDRPay SDR's. Thanks again.MonStat.jpg20220329_000440.jpg
ff026
ff026
The lights for the zetron. Do they light up for each input? Is there a busy light? Is the busy active by COR or a VOX circuit?
ShawnInPaso
Wow Tom, outstanding build!
I have to ask, did you cut your own rack panels? The appear much nicer (tighter fit) as compared to retail offerings.
Great job.
Shawn
