Tidradio TD-H3 ptt-id issue
scsi
I am a Linux-only user and picked the H3 because of the work "nicsure" is doing with reverse engineering and experimenting; they created a dot-net (.NET) based multi-platform flasher which has worked for me perfectly with the vendor stock firmware files: GitHub - nicsure/TDH3Flash (standard disclaimer, use at your own risk etc.)
They have other repos with their engineering work and custom firmware tests, if you want to poke around their debugging: GitHub - nicsure/TD-H3-Engineering: Experimentation with the TIDRADIO TD-H3
