Time for the pirates!
jwt873
Woodlands, Manitoba
By coincidence, I was listening for pirates just last night around 0100 UTC. Tuning between 6.000 and 7.000 Mhz. No luck. Will give it a shot again tonight.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
If you don't hear something with your own setup, use a web radio - and be sure to keep your eyes peeled on the various forums listed in the Pirate wiki....Mike
timhir25
Willoughby, OH
How would I listen on the computer. Could you provide a link for the web radio?
Tim
timhir25
Willoughby, OH
Thanks Mike,
I have my computer on the web sdr network. I didn't know anything about this.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Just by way of explanation, the Perseus listing is for those running the Perseus SDR on a network, the Spyserver listing is similar, but for those folks using Airspy SDRs on the Spyserver network, and SDR Console is for those folks using this app, usually with a SDRPlay device. Sadly that one seems to have more down nodes than those that are up
The Kiwi network, WebSDR and Global Tuners are probably the big 3. This is the DXer's 'secret weapon' - if a station isn't audible at that person's location, chances are there is a web receiver on one of these sites that can hear it....Mike
jwt873
Woodlands, Manitoba
Got one! 30 Nov 2020.. 00:15 UTC on 6955 Khz.
Tuning around I came across a Slow Scan TV signal on 6955 Khz. I thought it might be a utility station. By the time I got hooked up to decode the signal, it ended and the station switched to music. They've been sending an SSTV image between each song... Havent' managed to decode a signal yet. Can't seem to detect the format they're using... Will post one if I manage to.
Not a bad signal here in MB Canada. S5 to S9 with a bit of noise.
jwt873
Woodlands, Manitoba
Managed to grab a couple of SSTV images from the Pirate station.. They're 320x256 images. Quite a bit of noise. Just 'funny' memes, no station ID or anything.
Here's one: (Damn Skippy - It's Friday)
jwt873
Woodlands, Manitoba
Here's one more image.. Most of the SSTV images the station is sending has 'Skippy' in them. Did a Google for "6955 Skippy", and turns out it's a known pirate running as Skippy Radio.. Or at least it's known as Skippy Radio
( I decoded a couple more images that I can't post here on RR - Not family friendly :) )
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
If you are wondering about software to copy Slow Scan TV (SSTV) that too is covered in the FAQ linked in the first message.
Mike
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Ballsmacker Radio on 6960 and 3480 Khz AM. Playing the Monster Mash. A bit weak but there on the Alexandria Va. Kiwi. A bit better using SAM
Mike
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Radio Nova 4970 (yes in the 60 meter band) USB still going at this writing. Heard on the N4TVC Kiwi. ID per HF Underground board
Mike
spacellamaman
kruser
Well Known Member
W St Louis Cnty, MO
Been hearing X-FM on 4185 AM for a while this evening.
Good signal into the St Louis MO area at present. 0125 UTC
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Even the Venezuelan 'pirate' on 6906 is in there, not a bad signal into the N4TVC site. Didn't measure the exact frequency - it's rarely on exactly that frequency....
eorange
♦RF Enabled Member♦
Cleveland, OH
Heard a mostly unintelligible voice and some screaming on 6925 LSB earlier tonight.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
It's that time again - around Turkey Day is one time pirates start coming alive. Be sure to check these frequency ranges for activity...
  • 3200-3500 Khz (this is relatively new, no doubt taking advantage of the lower freqs due to winter in the Northern Hemisphere)
  • 4000-4200 khz
  • 5100-5200 khz
  • 6200-6450 khz for many Europirates, some Latin American pirates too
  • 6700-7000 khz
The hunt is on...Mike
(Edit) see this thread for an offsite wiki for where you can find reports of activity
