Tk-2180 mdc 1200?
ffemt25
Short Gap, WV
Hello,
I have a TK 2180 that I just updated the Firmware in to enable the MDC feature. For some reason I cant get it to work still. any help?
ramal121
Lots and lots of watts
Calif Whine Country
The "chirp" is called sidetone. If you're set up and sending MDC PTT ID ok, then you would enable sidetone in the program software EDIT>MDC1200>GENERAL. Note: sidetone only works on BOT (begining of transmission) ID's, not EOT (end of transmission).
Or is your radio not sending out the MDC data at all?
ramal121
Calif Whine Country
Set the ID you'd like to use in the MDC1200 window.
Then for the channel you'd like to send it on, click on channel edit and set PTT ID to BOT, EOT, or BOTH and you should be set to go.
