Tk 3180/8180 paging
Guard0910
Western, NY
My chief posed a Question, are the 80 Series radios capable of sending out tones to open up pagers. If so how? Thanks in advance
JEFF
mikegilbert
MHz so good
Los Angeles
Yes you can. Assuming you're talking about 2-tone sequential paging. According to kenwood, the 2180/3180 will encode 2-tone. Not sure how you go about setting it up, though.
ramal121
Lots and lots of watts
Calif Whine Country
Assuming you have software to set this up:
First go to EDIT>TWO TONE and under the encode tab name your page and enter the A and B tones. The timing parameters can be left as default.
Second program a button on the radio as "Two Tone".
To make a page, go to the correct channel, press the button for two tone encode, press the "<" or ">" buttons to scroll the menu list and then hit the PTT. Off it goes.
I use a portable to test with. If you're going to use it for testing and you're on a repeater, may I suggest setting the channel to talkaround and low power as so not to set off everybodys pager in the city.
