Tk-5710 v. Prolific-based programming cable
narnett
Morgan Hill, CA
Have any of you been able to program a TK-5710 with a cable using a Prolific chip? The cable I used for my TK-790, which worked fine with it, will not successfully communicate with the 5710 - it enters program mode then I get the "Check your connection" error message. I borrowed a Kenwood-branded cable (which uses the SILabs chip set) and it works fine (but I have to return it to my department), so I know it's the cable. I've also ordered an FTDI-based cable in hopes that it will work. Couldn't find anyone selling a cable with the SILabs chip set. But meanwhile, I'm wondering if anyone has found the magic to make the Prolific one work. I have tried changing the drivers to the recommended ones from Miklor; no luck there. Tried various port settings, too.
TIA for any guidance.
Q12
did the FTDI cable solve the issue?
devicelab
Radio N.E.R.D
WA (USA)
Odd, my Prolific cable works fine with my TK series... 5720, 5820, 7180, 8180 -- no problem... I'm using driver version 3.8.41
Are you sure it's a legit Prolific chipset and not a copy?
Q12
Posting For Future Reference.
The FTDI Chip TK-X90 Cable does Work with the TK-5710
