TK-690H-1 deviation adjustment ???
wcu02mpa
Asheville,NC
I have a TK-690H-1 that have put into the ten meter HAM band but the deviation seems low. Which tuning pot controls the deviation? The service manual is not exactly clear on this. I know the manual has a front panel method, but have heard there is a tuning pot to set this as well. What I have actually done is make a TK-790 to TK-690 (2-meter to 10-meter) bi-directional cross band setup and it works like a champ. It’s just a home brew experiment. I just need to get the deviation a little wider on the low band side for a better sound. Thanks…..
kd4efm
Florida
How are you feeding audio between the decks? That may be the key to the low audio.
Just thinking out loud.
wcu02mpa
Asheville,NC
A DB-25 cable the makes these into a repeater. Alberta Radio Supply sells them. I have seen this before when I dual banded a 790 and 690 w/6-meter freq’s. The audio is nice and loud, just would like to see a little wider deviation.
kd4efm
Florida
I have not play with the KPG for it, but like KPG-111, you should have a TUNE (CTRL-T) where you can adjust the softpot,but again, I haven't had the pleasure of playing with these.
